An evil clunk... (free beer)!!
hanshua
Blue Mounds, WI, USA
Ok... heres my problem..
I changed my PS fluid the other day.. it went great, except for that it came out alot faster than i expected... Man that stuff was black when i started...
but anyway.. that not the problem... I put my car on a lift to do the lock to lock stuff, and I think sometheing got messed up.. Ive had my car on the lift lots of time with no problem..
Now when I step on the gas from a stop i get a very pronounced clunk. this clunk can be felt and heard thgoughout the car. I can also make it clunk when i hit the breaks then step on it again.. I checked under the car, and couldnt find anythign obivously wrong.. and other than that clunk the car operates normally...
Any ideas?
-Justin
95 ATX
K&N Silencer-Coneless, SFC's, Strut Tower Braces, Yamaha Badges, two 12" kenwoods w/ 600watt amp and sony CD, CincySHO Cowl Hood, Removed secondary silencers, TPR bushings, fistanks, blazertech fogs.
Comming Attractions: New 17" wheels (need rubber for them), SS y-pipe, new springs to fix my sagging rear
ACV1081
Member #187
IA US
I have developed that clunk I think too & after taking it to an alignment shop they think it is a strut tower bushing or something to that affect. It seems to not be a pressing concern & they said just to wait till spring. It is sometimes worse sometimes better & sometimes not at all.... sound like anything you're expieriencing? Hope this helps but good luck in your manhunt.
1004303681370 NEW SHO PIC 102901
~Adam Varney~ mailto:[email protected][email protected]</A>
1993 RED ATX(3 replacements) W/shiftkit, 17" Konig Reigns, 245/45/17 Goodyear F1 Gs(Summer), 26mm ASB w/poly bushings, Tweaked stock airbox with K&N panel filter, D4U1 computer, blazertech fogs, & performance friction brake pads. GTECH time 0-60 in 7.02 1/4 15.58 @ 91.
Not yet installed: SHOSHOP Stut tower braces(front & rear), 24mm ASB(spring), all 60K service items, & rest of the poly bushings... Upcoming: Definitely saving for a y-pipe. GOING TO TEXAS Dec. 26 TO HAVE SDPATT DO 60K!
D
WOONSOCKET,RI,USA
I had the same prob., its most likely your strut brace. What happens is they slip in a stop a go. What you did is made the rubber bushing lubricated with ps fluid.
I had to get mine welded. They break free from the frame. {You think you hear noises now}. On a good note its an easy fix.
Fine89
Pottstown, PA
Mine has the same start/stop clunk. The Ford dealer said it needs both engine mounts. I didn't get it done - they want $500.00 and others here said it should run $300.
hanshua
Ok.. that makes sense to me.. Your talking about the "tension strut bushings" correct? My bushings are not healthy, but are holding up until I get my TPR's on the front..
I went in and talked to perf plus, and cathy said it might be the strut plate or something like that, but I'm scedualed to tgo in on the 28th so they can take a look at it.
Hopefully its something dumb like that.. because then I can do the work myself.. but if the struts have to be disassembled and all, I cant do that.. And, if I'm gonna pay for that labor, I'm goign to replace the front struts, because the rear ones need to be replaced.. and If I'm going to do all 4, I'm gonna get tokico/eibach so I dont have to worry about it anymore.
So.. in conclusion, Its either goign to cost me about $600 (replacing rear struts included) or about $1300
Ack.. I'm a college student..
-Justin
95 ATX
