Air\Fuel Ratio Gauge
Justin101
It's A SHO Thing
Rocky Hill, Connecticut
i just bought a Auto Meter Air\Fuel Ratio Cobalt Series Gauge, im just wondering how hard it is to install? it came with instructions but looks confusing! :smash: is it something i can do myself or should i have my local Performance Shop install it? thx all!
yamahaSHO
E85 whore
Arkansas
You can do it yourself... You just need to tap off one of the O2 sensors or install another one. I'd personally get a wide band O2 kit before installin an A/F gauge. The narrowband gauges don't really tell you much.
SASHO91
Zoom Zoom
San Antonio,TX
then again you dont really need a wide band on a non modded sho. Or better yet, a heavily modded one... but i would still get one..... :lol: jason were did you get yours from? i want one too.
yamahaSHO
E85 whore
Arkansas
I got mine from www.plxdevices.com.... Josh carries them. And yes, you do need one on a heavily modded SHO. I mention a wide band because with out it... you're just in it for the light show.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
As Jason said, running an Air/Fuel gauge off the stock sensors is really not going to tell you any worthwile information. A wideband is an *extremely* good idea for a modified car - without it you will have no way of knowing if you're running to rich or leaning out.
SASHO91
Zoom Zoom
San Antonio,TX
Wow i get flamed really hard for mis-typing something. i meant, or better yet a heavily modded sho need one..... i meant it like the heavily modded needs it more than a stock sho..... my bad....
Justin101
It's A SHO Thing
ok guys thx but where do i get one of those wideband sensors? off that site? and how much do they run? and can i just get the bosch wideband sensor or do i have to get the whole $300 kit?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
You have to buy the controller along with the sensor, so you will need the full package. If you're just looking for the gauge to look cool and give a vague idea of how the motor is running, you'll be fine with the stock sensors. If you really want to know how the car is running down to a tenth of a point AFR, then the wideband is the way to go. If you're planning on major mods to the car, a wideband is a good idea. Otherwise, chances are you don't really need a WBO2 setup.
Justin101
It's A SHO Thing
ugh thats what i thought. im not running huge mods right now, i just have exhaust and cone filter intake. i may run a larger MAF in the future but thats my extent of the engine performance mods. now i cant jus get the new bosch wideband sensor and get the narrowband to wideband converter? all i want is a relative idea of how my engine is running.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Chances are you can just tap into the existing oxygen sensor signal then. It will move around a lot (looks cool) but what you're basically looking for is that it jumps to the rich side when you get on it.
DavidT
TN
you want to tap into the 02 wire on the ECU side, not the 02 sensor itself. In my ex 91 I tapped into the ECU 02 wire located in split loom coming up near the oil dipstick tube/ intake plenum. I BELIEVE it is a BLUE wire. I am not 100% sure though. (maybe green, ahh heck...)
It is JUST a light show though/ gauge pod filler :biggrin:
However, $300 is too steep for the real deal (wideband 02) IMO. Unless your sho is a dragster.
Here is pic.:
Scsho088
yamahaSHO
E85 whore
Arkansas
The ECU is probably the better way to go, but you can tap directly off the sensor itself. You're just looking for the 0-1 volt signal.
