AC System :-(
Troubled93
Charlotte, NC
Ok just got in from adding refrigerant to my AC system and still blows kinda warm... reset computer and let the car sit for 15 mins maybe for the refrigerant to settle in the system and nothing... Do you guys have ANY absolutely ANY ideas of what I can do next to try to get this thing working properly...
When it does "nothing" does the a/c compressor clutch kick in, or not? If you jumper the low pressure switch, does the clutch kick in?
Troubled93
Charlotte, NC
how do you jumper the low pressure switch? i am not too savvy on this stuff but if you have any instructions that would be helpful
SHO1
Coke Is It!
The State Of Hockey
Unplug the connector from the pressure switch on top of reciever/dryer, which is located down low between the batt. and rad cap, very close to the ac clutch/pulley. And jump the 2 terminals on the plug while car is not running and key off, then start car and turn the ac to max and clutch should kick in if it works.
