Hey all, I had a weird happening today with my ABS brakes. Usually when I start my car, the ABS motor pumps once and the light disappears. ABS system passes initial self test. After I get moving on every day except today, the ABS light kicks on at 10mph self test.
I was leaving work today, and the light never came on after passing initial st. I thought that was kinda weird, so when I could, I slammed the brakes, and oddly enough, the ABS system worked as it should until about halfway through the stop, when the ABS stopped pumping the brakes, and the light came on. I should also say that the pedal felt like it was fading during ABS operation. (Maybe pump motor hasn't been bled. How can I bleed ABS system without working ABS and no ABS bleeder?)
I've tried pulling codes in the past, and Tony has tried as well, but all we get from the light is steady on. Any ideas as to what's causing the problem? Initially I thought it was wheel speed sensors, but after today, I'm thinking that's not the case. Please help, I really want to figure this out so I can get some bias plugs, cuz I'm not doing that before ABS works.
