Abs Module Nigtmare
Mr Anonymous
Tire Wall
i know they are 2 different units the pump itself and the module, the problem i am having is the conflicting reports i am seeing on here and elsewhere. now without running the risk of getting responders upset, i mean no disrespect, i wish some one would lay it down and tell me what i need from experience thats all once again thank you
It really doesn't get much clearer than this:
It is G3 SHO specific but not year specific.
The electronics and pump motor/solenoid valves are two parts of the ABS system. You may be able to just replace the electronics. But when I did mine I could not get the large 30 torx bolt out to separate them so had to replace the entire unit.
Ict_Lx
Back in School!
Marietta, Ga
I'm in the process of doing this very thing right now. It's not a lot of fun but it's doable. The battery trey is a huge pain in the rear end. I still need to take some time and get back out there to work on it and get everything back together.
shogun
minnesota
my tech said the abs pump is fine it is just the module, so since we cleared the compatibility issue i would now need to know how to remove and install a new one. any ideas??
by the way thanks guys for taking the time to help me on this, just want you to know i appreciate it
It's held together by five torx screws. 4 smaller ones on the corners and one large one in the middle.
They are made out of grade 1 steel and twist off with the greatest of easy.
Good luck.
shogun
minnesota
could you tell me exactly where it is located pls SHOZ123 and is there anything else to it?
thanks
SHOMEX
Taylorsville, Utah
ABS Module
Shogun, just check the tread in this very same section it has some nice pictures of the module; look for this tread :Sigh... P0500 and dead speedo
shogun
minnesota
i wanna take this opportunity to thank u guys for helping this noob, i know it is as hard as ***** training an infant but i think i am getting the gist of it so thanks a lot i am pulling the plug on the repairs and i am going to do it myself
97SHOgt
Cincinnati, OH
I just did this not too long ago. You shouldn't have any problems. It's not QUITE as bad as everybody says. Just be ready for some busted up knuckles! Any questions, just ask :thumb:
Ict_Lx
Back in School!
Marietta, Ga
Anyone know what the thread pitch of the hard lines that go into the ABS module is? I think I may have screwed one up putting everything back together. It's not cross threaded yet but it's definitely rounded more than it should be. Thanks!
Edit: Nevermind, precesion file set FTW!
