Abs Module Nigtmare
shogun
minnesota
i hope my band of SHO brothers and sisters could help me with ONE. i found out recently and painfully that these cars don't have a sensor called the VSS, the od starts flashing and i have to manually shift an auto gen 3 from 1 to drive, my speedo is out and i loose power totally when this happens , my new mechanic told me that the electronic side of the abs module is messing up, are there any ideas out there on how to get my hands on a module if that is the problem
thanks
shogun
minnesota
No i did not, its at the mechanics shop now and he is the one that told me that the module is not communicating, if this is just an ABS related issue can i bypass the abs so i could drive the car??
NebraskaSHO
Harumph!
Omaha
My car has no ABS and it drives fine.
By no ABS I mean it's all there but "it" doesn't work. Brakes work fine, just have to be sensible when conditions aren't perfect.
shogun
minnesota
well is ur car a gen 3 cause it seems like it will never drive nice unless i get the module fixed in which case i need to know if a bypass could be done if any so i can enjoy this car
You can't bypass the speed signal in the ABS. It will need to be replaced.
shogun
minnesota
so i need the module then, my tech is telling me that he is unable to locate one any where. where would i be able to buy one at
97SHOgt
Cincinnati, OH
My ABS doesn't work in my Gen III either and it hasn't been a problem. I actually found a used module and replaced mine less than a year ago. Thought I had the problem fixed but then shortly after it stopped working again. So I went through all that trouble of replacing it for nothing. Oh well...
shogun
minnesota
well i had my situation diagnosed by a qualified technician and as soon as i can get my hands on this part i will be good to go, once i get it fixed i am going to sell it ASAP any bodyhave any ideas where i can get a abs module in mn
97SHOgt
Cincinnati, OH
Try Midnight Auto's store on ebay. They have a ton of parts for Gen III's. If you don't see one on there, send him a message or something to see if they have one not posted. I bet they do. I've bought a few things from them and have been very satisfied. They just had an ABS pump on there not to long ago. Good luck!
shogun
minnesota
My Tech Just Told Me I Have To Get One Specific To The Yr Which Is 98'' Is This True
shogun
minnesota
It is G3 SHO specific but not year specific.
now i am conflicted, on the one hand i have my tech tell me he phoned in to ford and they told him it is yr specific and then i am told it is gen 3 specific i am so lost and confused
97SHOgt
Cincinnati, OH
More often than not, the Ford dealer has no idea what the **** they are talking about. Paul (SHOZ123) is a very reliable source. He wouldn't steer you wrong :thumb:
NebraskaSHO
Harumph!
Omaha
The ABS pump thing is SHO specific. Talk to Ray at Midnight auto on eBay and find a SHO pump.
Yes, I have a Gen III.
Be warned, the battery tray is a real PITA!
shogun
minnesota
So just so we are on the same page i could say take the ABS module of a 96 and use it in my 97 without any problems, i would be really happy if this is the case pls help
Mr Anonymous
Tire Wall
St. Louis, MO
Well, just ignore all the knowledge and experience here, and go with what your tech and Ford think. :shakehead
I still doubt you have a dead ABS computer. It's a rare failure. Fuses blowing and the main ABS harness coming loose are far more common.
Regardless, the computer can be replaced without changing the pump.
shogun
minnesota
i know they are 2 different units the pump itself and the module, the problem i am having is the conflicting reports i am seeing on here and elsewhere. now without running the risk of getting responders upset, i mean no disrespect, i wish some one would lay it down and tell me what i need from experience thats all once again thank you
