ABS issues - 1991
TankII
Bolton, CT
I've about had it - almost had two accidents yesterday.
Where is the fuse for the ABS module? I cannot find the "High Current Fuse Panel" under the hood.
ABS codes (in order flashed at me):
22,32,35,36,37,44,43,63
I believe I need to replace the rt-rear caliper, since it barely turned when I put new pads in, but that isn't the reason for my issues.
Unless a rodent chewed some wires...
Unplugging the fuse is the fastest fix on a Sunday.
Thanks in advance!
high current fuse panel is on the drivers side inner fender to the rear of the airbox - a rectangular shape with a cover you pop off to get to the fuses.
TankII
Bolton, CT
It doesn't exist on my car. Behind the airbox is the starter relay, and then the transmission shock mount to the side of the strut tower. Behind the strut tower is the ABS diagnostic port and a relay, which I'm assuming is also for the ABS.
TankII
Bolton, CT
Ugh. Then there is no way to disable the ABS without pulling the relay, assuming I find the correct one. Seems strange they would put a fuse on '92 and up cars, considering they came out with ABS in '90 for the Sable and SHO.
Thanks!
sorry, I had forgotten that the 92+ cars were wired that much different...
