91 FAILED EMISSIONS Need Help Fast
jon93
Philadelphia Region
I failed PA Emissions test today. My numbers are as follows:
CO- 1.86 out of an allowed 1.10 FAIL
HC- 918 out of an allowed 275 FAIL
NO- 9858 out of an allowed 3600 FAIL
I have no clue what to do in order to correct this. Any help would be great.:oogle:
hawkeye18
Sorta cares
Norfolk, VA
It looks like your cats have gone through their 9 lives, and then some. They are toast. Ordinarily, I would suggest pulling the SPOUT plug (search that term for detailed instructions), but yours are so far out that even that probably won't fix it. You really need new catalytic converters. And your engine probably needs a lot of help. I would suggest Auto-RX (that specific brand!), as it, and it alone, has been shown in a LOT of SHOs to help engines out a lot, at least for short to medium periods of time.
hawkeye18
Sorta cares
Norfolk, VA
hmm... high n0x is usually high cylinder temps, right? Is your EGR system working? Do you have one installed?
1993MTXSHO
Its a Taurus...
Jersey
cats cats cats I told you this already, what you don't trust me? ok so I wouldn't trust me either:rofl:
BTW I have a good stock mtx y pipe ill let you borrow since im so nice, i need it back though so you only get to use it to pass emissions and lose hp for a week :biggrin:
jon93
Philadelphia Region
I haven't checked the codes yet, but it does need plug well seals. The previous owner told me he did plugs, wires, timing belt, water pump recently.
dohcsable
Gold Calipers>*
Indiana
dismantle the catback.....then when they go to hook the things up to the tips.....you'll be fine.....just keep fireballs under the car to a minimum.
Ok, so that won't really work....new y pipe, or find a guy who can pass you for a small monetary amount....
Andrew
jon93
Philadelphia Region
FPS has replacement cats for my Ypipe at $100 each plus shipping plus install. A new Performance Plus Ypipe costs $525 so thats a no. My only other option would be to go with a Magnaflow Ypipe which is like $250, but I've heard about fitment issues and it would be a downgrade from my current pipe.
Westerly, RI
Borrow that other stock pipe to pass emissions, while yours is out have the cats cut out and pipes welded in their place for a catless y.
What kind of y-pipe do you have now?
hawkeye18
Sorta cares
Norfolk, VA
well if he has to do emissions, and he's failing cos his cats are bad, I don't think going to a catless y-pipe is going to solve anything. You need to replace the cats. If you're willing to swap y-pipes out twice a year, then I guess go for it... but I think that would be a lot of effort.
sho_ted
Albany, NY
i am really glad my 94 only gets a visual emissions inspection, all the "check engine" light" must be off.
1993MTXSHO
Its a Taurus...
Jersey
jon the idea of borrowing my pipe, was to gut ur cats and then still be able to use that pipe so you dont have to buy anything:thumb:
AREA 91
PA SHO SHOP
Area 91
Bring your SHO to me. I can do the rest of the 60K service and hook you up with a good stock Y pipe. I stock SHO parts.
I'm in Selinsgrove, PA 17870
P.M. if interested. Brian:thumb:
jon93
Philadelphia Region
Nice, I didn't even think of gutting the cats.
Brian, I'm definitely coming up to your shop sometime. You have some nice cars. I can do 60k's, I just don't have the rotunda tools to do the heads yet.
dwarf
Martinez
My 94 mtx has gutted cats and when I pulled my spout connector I passed by 1ppm. ONE PART PER MILLION LET ME SMOG.
I say run the car hard, pull the spout and have him smog it? you usually get a free re-test at least? Anyways its only 40 bucks to smog for me and that comes wiht a free re-test.
I smog and fail my Rx7 every 2 months
jon93
Philadelphia Region
The place i get it done at won't let me wait for it anymore so I don't know if running the car real hard before i take it there will work. They used let me wait but they got some new *** management but atleast they not picky about little stuff like everywhere else around me.
This would be my free retest BTW so I really want to pass this time.
I have some Berryman's B12 in hand that I want to put in the tank to clean things out. Any thoughts??
jon93
Philadelphia Region
I have a performance plus stainless steel Ypipe. I think i would weld pipes inside the cats to keep the look and integrity of the original pipe.
dohcsable
Gold Calipers>*
Indiana
just put a cutout under there......they'll wonder why its loud and the rooms filling with smoke, yet you test good.....hahaha
Just tell them to shove it, and go to another place to test...
Andrew
bmytych
