AIrcraftMech
O.K. I'll show my age with this old trick.
1st. Run the car out of gas
2nd. Change your oil
3rd. Get a case of gas line antifreeze
4th. Put the WHOLE case into the tank
5th. Put two gallons of High Test into the tank
6th. Drive straight to test sight, make sure car is at full temp, not cold
7th. Run test, you should pass
8th. Bottle of Marvel Mystery Oil, double recommended amount in the tank
9th. Fill tank full of gas
10th. You should be a happy camper
I've done for a couple of people. Never had a problem. ONLY do it to pass test. Gas line anti freeze is mainly alcohol, NOT GOOD FOR SEALS & OR GASKETS. Worked on, Honda BMW, and Toyota.
Then again, the "It's not what you know, it's who you know" works too. My little bro couldn't get his Land Cruiser to pass in VA. Called me singing the blues about how much it was going to cost. I called an old friend, told him what was going on. He laughed and said for him to bring all the info for the cruiser over, but come in the porsche. He put in all the info for the cruiser, but ran the porsche on the test. Cruiser passed with no problems. Don't know if you could do that one or not, though.
