CardinalGopher
My '89 SHO died on the freeway suddenly at about 75 mph in 5th gear on Friday night. I got the car onto the shoulder and towed home.
Here's what I know about the problem: I get codes 11 & 66 from the EEC. 11 is the System checks OK code and 66 is the Mass Air Flow Signal Low code. The engine cranks fine and the fuel pump, which I assume is the high pressure pump, runs when the key is turned to the on position. I've put a timing light on all six plug wires, and all six show that they're receiving spark when the engine cranks.
I haven't checked the fuel rail yet to investigate if it's actually getting fuel when the pump turns on. My thought was to loosen the fuel pressure relief valve and then ground the self-test pin to cycle the fuel pump and qualitatively verify that the fuel system is working.
The bigger question I have surrounds the 66 code. I have the OEM 1989 Car Shop Manuals for the car (both Vol. 1 & 2), but not the Engine/Emissions Diagnosis Manual. What does that manual say to do in the event of a 66 code? Is a bad MAF sensor enough to totally **** the engine at highway speed and prevent it from starting again?
I also have yet to try clearing the code by disconnecting the battery cable and then running a key on, engine off test. Does anyone know if the engine would fire on cold start if it had previously found a 66 code that had been cleared?
Any thoughts?
Adam
Any thoughts?
Adam
