Can you believe that? 85,000 miles and the engine started knocking. My car is in tip top shape. Mobil 1 since new changed regularly, Mobil 1 and K&N oil filters used, 60 k done, new water pump, all new sensors, gaskets, etc. I replaced stuff that didn't really need replaced. I even already had the rod bearings, since I was planning on changing them soon as preventative maintenance. Well, I guess I didn't change them soon enough. When it started making the noise or actually when I realized that it was, it sounded like it was coming from down low and I figured rod bearing, but didn't really want to accept it. So I dropped the pan and the oil pan had a lot of copper shavings in the bottom of it. It spun the 3rd bearing over from the flywheel and the 5th, counting from the flywheel side. The 3rd one over left marks on the crank that you can feel with your finger, but the 5th one over had just begun to spin and was very smooth. I figured what do I have to loose, so I got some crocus cloth and tried to polish the crank, but it didn't seem to do much. I decided to put new bearings in all of them. I plastigaged the spun bearings and they were actually in spec. Got it all back together and when I started it up, it was very smooth and I thought allright!, maybe that will last for a while. Yeah, It lasted for about 20 miles and started knocking again. Soooo, I guess I need a new engine.
So that's my question, what to do?
1. Put in another crank without problems?
2. FPS has a <12000 mile 3.0 motor ($2000) or they have a rebuilt and bored 3.3 motor $3000 for just the short block.
3. Junkyard 3.2 and change everything over.
4. $1200 ebay motor with less than 52,000(so they say)
Talked to somebody and they said don't regrind the crank, because it is hardened and won't last long if you regrind it and put in undersize bearings. Is this true?
My car is too nice to not fix it up right. I kinda like the idea of new stuff, since just about everything else on the car is new.
What should I do?
Will
What should I do?
Will
