If I were to buy wjayg's 3.2 engine parts collection:
"I have a complete 3.2 engine
The block has been dipped & honed
Heads are bare
Crank is in excellent shape $50.00
Block, heads, crank have been wrapped in plastic and all parts stored in climate controlled garage
Complete wiring harness $45.00
exhaust manifolds $25.00
3 piece Timing Cover $65.00
I was going to build and have decided to go a different way
I am missing cams, valve covers, and intake"
What else would I need to make the swap happen? I obviously understand there is a difference in accessory drive setup between the two engines. I have a 3.0 that is fairly healthy (has slight valve tick but needs a 60k and runs some kind of cams I believe so Id imagine wear is worse than with stock cams) and would plan to use it's intake, cams, and valve covers.
1)Would I be able to adapt the 3.0 accessories to the 3.2 using the 3.2 heads (what would I run int other than notching the front head)?
2)Would I need different size rings for the hone job? If so is it worth boring it out to run HC .020 pistons? If that is the case what would a machine shop need to get the bore right as it changed slightly due to honing and I'd want it tight?
3) Could I use the 3.0 timing cover with the 3.2 oil pump?
4)Would I just be better off spending a bit extra for a whole 3.2?
:thankyou:
Heads are bare
:thankyou:
