3.0 wont idle
leek157
illinois
Earlier today after some spirited driving my car cant seem to figure out how to idle. at first it was sitting up around 5k then would surge from 1-2k and after trying the idle reset procedure it still sits around 2-25k
Ishodu
Sounds like you may have popped off a vac line or something. Take a look around under the hood to start with.
leek157
illinois
I was thinking I might have a vac leak I didn't hear anything that stood out but ill take a closer look, are there any common lines that rot thru or something
leek157
illinois
the cruise was not letting the throttle close completely so i just disconnected it. it stalls sometimes now when the clutch is disengaged or surges a little bit but i think that might be because i disconnected the ecm and batterey thinking the idle needed to be reset
