2 amps in my sho?
filc03
Eaton, OH
I have a 92 w/jbl sound system. Looking in my trunk there's the black box which I know is an amp, but what's the silver box mounted left of it? I'm guessing one powers speakers, the other powers the sub, but is this right? If I set up the bypass, which one do I bypass? And also, how am I supposed to get out the rear speakers?
<small>[ March 19, 2003, 08:43 AM: Message edited by: filc03 ]</small>
30footSHO
In da mountains
Boise, ID
The silver one is for your speakers. The black one is for your sub. As far as bypassing, I do not know. I'm still using my factory amp for the time being. You would be bypassing the silver one, yes, but my SHO was born without JBL sound.
Dave
Edit: you remove the speaker grilles with a knife or other thin object. They pressure fit down into the package shelf. Be gentle and try not to bend them too much. After that, a short screwdriver or a socket will suffice.
<small>[ March 19, 2003, 02:25 PM: Message edited by: 30footSHO ]</small>
Guido
Wiscasset, Maine
Dave's right. When I installed my aftermarket HU, I bypassed the speaker amp with the bypass harness. As far as I know, this eliminates the sub all together, so you don't have to worry about bypassing that amp, too. The stock speakers (if you still use them) will run off the new HU and, in my case, sound a **** of a lot better.
On rear speaker sidenote, if you want them for decent midbass (fill reasons), I'd suggest an aftermarket pair. Once you remove the stock ones, you will see why I say that: The magnets on the stock JBLs are about the size of quarters.
-***** (Laughed the first time he saw those tiny, tiny magnets...)
Speedy_91_SHO
Toledo, OH
On my 91, i think I have it figured out that the black one powers the spekers and the silver one powers the subs. thumbs_u
John
PA
You can bypass the amp with the bypass harness like stated. Deffinatley worth it when you have a headunit that probably puts out more watts than that amp.. thumb
John
95 SHO Mtx
tido
Seattle, WA
on mine, it's the silver one that powers the sub, not the black one. at least, that's the one that was removed when i put in my own subs/amplifier.
-tido
SilverSHO
cartersville
I have the JBL audio system, and four speakers in my rear deck...two 5x7s and two 6x8s. The 6x8s are held in place by big rubber straps and, for factory speakers, have pretty hefty magnets on 'em. The 5x7s' magnets, IIRC, aren't as beefy, but are bigger than the puny little stockers in the rear deck of my mom's '98 Sable, which I think are the size of quarters.
I like my front speakers, though. Just need some tweeters up front to help them with highs, though (got 4 sets in the garage :D ).
