old yellow head lights on GEN 2
91 shonice
dover plains, ny
Just got the gen 2 and the plastic on the lens are yellow from age. anything I can do to clean them up or do i buy a set. I priced them at auto zone and they were $80 each.
spazmoid
RI
check on ebay, i picked some up for a 2nd gen sable for 35ish each. They don't have the fishtanks but they will unscrew off yours and on to the new ones. They aren't quite oem quality but for the price they arn't bad, then maybe you can just clean up the fishtanks alittle to make them match better.
johndallara
Chapel Hill, NC
replacement headlamps
have gone through 2 set of autolens bulbs, both got water inside imediately after the first car washing. maybe a bad batch. last time i coughed up some $$ and got new OEM from ford.
PM me if you need a few headlamp clips.
JD
:salute:
Phoenix
SHOHOLIC
QC , Canada
35$ each at rockauto , go for sable lights.
Even comes with the bulbs. Swap the fishtanks , and voila.
spazmoid
RI
the ones i got from ebay which were just like the rockauto ones were something like jenco, they needed a little filing of the plastic to make one of the fishtanks fit flush but what do you want for 35 bucks right? Overall i'm happy with them
frosho
WOLFMAN
Tyngsboro, MA
FWIW, if you don't feel like buying new lights, a little wetsanding and some Meguiar's PlastX will help out a good bit. Less than $10 as opposed to $70+.
Storm-Chaser
Shit Louis
If you're going to refinish your headlamps, use the micromesh kit.
I tried Plast-X and several other polishing compounds sold specifically for headlights. Short-term results were okay, and none lasted for more than a few months. In every case, the yellowing returned and became noticeable within 3 months. In the case of the Plast-X, it even caused one of my fishtanks to start yellowing, after I used it to try and remove some minor pitting (which it didn't do).
The OEM lens had some type of clear-coating to inhibit the UV yellowing, but I don't recall anyone posting what type of factory clear-coat was used.
May be Denny knows or can find out . . . .
kevinspann
Don't take my advice.
Richmond VA
After the wet sanding and polishing, why not have them clearcoated? I suppose that would make it more expensive, but they would be OEM lenses, versus aftermarket ones
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
The polish kit I used on the malibu had a coating to apply after all the sanding and all was done. Still can't find that kit tho anywhere. Came with all the sandpaper and everything needed.. was pretty convient. Was actually looking for it tonight.
SHO Continental
Moderator
Northridge, Cali
A SHOCal member did that to a set of lenses he picked up after wrecking his SHO. Sanded the lenses, (took the three bumps off too), etc etc, then cleared them. You still get the yellow from the old glue though.
DSCF0395
