Fog Lights
Grand Rapids, Michigan
Saw this was already ideated by someone else but never saw anything come of it, so I ended up doing my own. I do a lot of night driving especially in the winter time, when here in Michigan it gets dark at 5 o’clock. I ordered some HDPE plastic to try and flush mount, but I ended up using a bracket instead. Using some cheap lights off of amazon, as well as brackets and a wiring kit, I made this.Effaec1a51871247b775f1c97897f67c
288fc94acdb0dcd9b56b2ea78a16c3e5
6bdf38d044aed208d5557c590d031692
962de29029579488f89b4589345590d1
Ec1b18677cedb5d22998c0e3dfce2c39
definitely not the prettiest, and I need to level the lights on their brackets, but a great start. 5c174b7c96ab33ca96cac9d722264cc5
15817e6d1579c3e2290c5357e6a30fc4
Some pics with them on. Have yet to use them in rain or snow, but hoping they do well.
They also do not interfere with the cruise control/collision warning system, but they also are not directly in front of it.
SnuffyTheSeal
Florida
Might have to do this so I can drive my Taurus at night again up here... Need every advantage I can get against the White-Tailed Menace.
ForcedAccountsBad
Kansas
How'd you wire this all up? Does it all go to a single button somewhere under the dash or did you do something more intricate?
I was lazy and just bought a wiring kit on Amazon. Single toggle switch for it. I plan on wiring into the ignition once it warms up.
Deezuz
Indiana
I picked up diode dynamics awhile back, but I'm going to remove the lower grill insert, cut 2.5in holes, and mount these inside....
2352
This photo is AI
2354
The cruise control module is right behind the drivers side, I don’t know how much you care about it being covered but sometimes I’ll have issues with my cruise not working.
ForcedAccountsBad
Kansas
I picked up diode dynamics awhile back, but I'm going to remove the power grill insert, cut 2.5in holes, and mount these inside....
This photo is AI
AI or otherwise this is more or less what I'd like to do at some point! I'm looking more towards something that can go flush with the bottom but I'll give that up if it means I can have some good fog lights.
Deezuz
Indiana
I'm assuming your thinking electrical noise/interference?
I don’t know why it doesn’t work sometimes I haven’t had the time to trouble shoot it, but I assume it is that or just the light shifting on the mount and momentarily blocking the sensor.
