Twin turbo possible?
Sammy~D
Wrench Whore
Anoka, Minnesota
lol i donno if it will dont think it will fit but i was bored so i drew it up...for when we can make a sho rwd
Sammy~D
Wrench Whore
Anoka, Minnesota
their a taurus 2 door rwd
strings1732
RMTE-TRBO-SHO
colorado
so a RWD set up engine in a FWD car is harder than a RWD engine set up to a RWD car...
especially since a SHO engine will barely fit into the engine bay in a RWD application
in the sense of modifications needed, then yes... the 240 needs everything built from scratch, where as the sho, could use a lot of already pre made parts, off a mustang, hence the reason it is easier. Instead of having to redo everything to get it to work, you basically turn the sho into a mustang, with a sho motor/body. it's easier in my opinion.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
All of this crap posted and not a single post answering the main question I had. Will the Chrysler 2.2l/2.5l turbos flow enough if I use one on each bank? I dont know a thing about turbochargers and thier flow........
Thanks
James
Power Surge
Palm Coast, FL
Thanks
James
Yes, they should work well.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
Oh, forgot to ask, does anyone know what those turbo's are called? t4 or something? Does anyone have a couple laying around? :evilgrin: This is not for my white 95. This would happen to be for the SHOWagon
Power Surge
Palm Coast, FL
idk i have the 60t t3 and the 50t t4 the are monsters compared to the CRYslers turbos ive seen
It sounds like you just don't know turbo terminology all that well. The "trim" size is just the ratio of the big and small ends of the impeller. Trim size has nothing to do with the turbo size itself.
A T4 is larger than a T3. And then you have T3/T4 hybrids, which are VERY common and nice small engine turbos.
TT SHO PROJECT
OHIO
why not just make a twin engine taurus... leave the front engine where it is and add another to the rear. 2 sho engines in one taurus, tubed chassis all wheel drive.
Its been done already... search for "v12 awd" on here and you will see.
or wait i think that mite be a topaz tho... hmmm...
