shoforum and shotimes comes thru again.
F-22 Raptor SHO
7015 feet above Sea Level
Oh what a search (that lasts more than 5 minutes) can turn up when you know the answer is out there.
I have a leak not from the water pump, but the gasket between the water pump and the down pipe that leads to the lower radiator hose. After a few hours of dissassembly I was trying to tighten the allen screw that secures this pipe. Well there are two of them...one in the front and one out of sight. Son of a ....... how the heck is that one supposed to be tightened, let alone replace the gasket?
I've done a few water pumps, but only the halves, I've never had the whole assembly off.
Well waddya know, after search of shoforum I found the link to showtimes (a sight I am rarely at anymore.... I found this http://www.shotimes.com/php-bin/mod...le=article&mode=thread&order=0&thold=0&sid=64
which shows that the whole assembly comes out with 3 bolts, which means I can replace the gasket after I remove the whole thing, not replace it with the pump on the car.
Search function and patience is the key.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Just visited that wikisho site, it seems to be incomplete in a major way, with a lot of links sending me the same message (you clicked a link that does not exist - or something to that effect).
TT
hawkeye18
Sorta cares
Norfolk, VA
That's just because YOU haven't created the content yet! get to typin'! I already made like 10-12 pages in it. You know how a wiki works, right? The users create the content... just like wikipedia.
