haha I could sold you mine already blacked trim around that piece...Working on the windows now, I think I want to keep the SHO touch of chrome...time will tell if it looks silly once the window trim is done, but so far liking it
Yeah I do like yours, I'm going to let the SHO hang for a little before I decide if I want that gone tooas u can see even in my thumbnail, went PI and no model shown
I agree with your assessment of the feel spot on. that connected feeling I got over pretty quickly. yes most daily drivers would shiit if they felt the slight vibration, thus the sloppy mounts they install.Swapped these out for the AD mounts. Was a bit of a pain in the butt, but got it done.
So far what I've noticed... Sounds louder/meaner in the cabin. I'm not mad at it. It also feels more analog in steering wheel with me. Can feel more vibration. It's not terrible but I definitely feel a little more of that rumblyness. It's idling right at around 5-600rpm so that might be doing it
Shifts feel smoother but wasn't able to truly get on it from a stop to try out a big 1-2 shift.
This car is starting to feel like a performance vehicle to me now. Next stop lower chin spoiler and lower engine splash shield replacement, have ordered whiteline sway bar that gets here tomorrow, and I got a good deal on some barely used bc coilovers as well. Waiting for my ppe downpipes to be made and shipped and will do intercooler and downpipes at the same time.
To be honest, I'm kind of tempted to try meth injection And do it at the same time as everything is going to be off for the IC and downpipes already. Thoughts?
Those mounts will break in and vibration will lessen. If you are tuned, go into the tuning device and raise your idle rpm by 100 -150 rpm and that will help as well.Swapped these out for the AD mounts. Was a bit of a pain in the butt, but got it done.
Also something to think about......Swapped these out for the AD mounts. Was a bit of a pain in the butt, but got it done.
Thank you. This is an interesting read as I live in a place that is usually only 50-65 degrees out during summer and wintertime it's 30s or lower all winter so I always wondered if I'd need intercooler or if it could make me lose power if it ran too cool. It's sitting in my garage now though so..Also something to think about......
So from my research most stock SHO's put about 290 HP and 300 TQ on average.
Full disclaimer: Brad from AJP Turbo is the only person who has tuned my car.
When I first tuned the car (plugs, K&N drop in) on 91 it made 366 HP and 414 TQ in 105 degree heat. so +76 HP and +114 TQ over stock.
Next was the E30 tune. Car made 391 HP and 470 TQ on 91 octane with Torco T85 E30 mix in 90 degree heat. E30 added +25 HP and 56 HP for a +101 HP and +170 TQ over stock.
Literally just the AJP Turbo E30 tune was the biggest bang for the buck in my build.
Then came the GH IC. The car actually lost power in cooler temps with a revision. The GH IC was a bit too big for my particular turbos. Car made 388 HP and 463 TQ on two less PSI of boost. So -3 HP and -7 TQ made +98 HP and +163 TQ over stock. Brad did state in an email this could happen, because he was seeing boost tapering bad on my car in the logs.
Next my full exhaust mod. Revised AJPTurbo E30 tune on stock HPFP, Gearhead Intercooler, PPE Catted Downpipes, Custom Magnaflow Resonator. DP's and Custom Magnaflow Resonator, going throught stock mufflers netted me +3 HP and +24 TQ bringing up the numbers to +101 HP and +194 TQ over stock.
Finished the cycle with the FS HPFP (who I bought from BPD) and removed the GH IC and replaced with a stock unit. I documented it in detail earlier in this thread. Brad sent me a revision for the HPFP and stock IC. Car was on 91 mixed with pump E54 for pump E30. Car actually made 414 HP on the first pull but TQ didn't register because of the connection to the MSD coils. He fixed the issue and the second pull netted 411 HP and 546 TQ. However if you look at the dyno sheet, he didn't actually get the true peak. It is probably in the 555 to 565 TQ range because it was already falling before the dyno recorded. So +20 HP and +52 TQ finishing the numbers at +121 HP and +246 TQ over stock.
After thinking about it more my top three mods would be:
HPFP with whatever octane tune you can run
H&R Springs
AD TQ Mounts
That would give the owner the ultimate foundation. Good HP and TQ, better handling, almost eliminate wheel hop.
A good set of tires would be next, however most people don't think of those as a mod.
You could order a 55 gallon drum of E85. I personally use Torco. I pay $480 for 55 gallons.I get what you're saying about E30 tune though so have been looking at ways to easily replicate higher octane fuel without absolutely getting murdered with shipping. I guess I could order 5 gallon containers of t85 but that's like 50-60 bucks plus shipping each fill-up. That seems a little wild
Well, tell us the story.Fixed all trunk leaks...
Ugh. Usual culprits were leaking. Plugged the taillights, spoiler bolts etc. I found an actual seam was seeping as well as the top left trunk lid. I finally broke down and sat in trunk with waterhose going. I parked it nose down and plugged everything, then nose up and made sure everything was plugged. So far so good. I feel intimately familiar with this cars trunk. It's been the bane of my existence so I'm looking forward to driving this thing in the rain guilt free for a week, and then getting angry when it turns into a swimming pool again next time I checkWell, tell us the story.
Forgot to show her in all her glory. Look at that. bone dry.Well, tell us the story.
Battery.While driving the sho around last night I had something strange happen. My brights were automatically turning on by themselves and I could t turn them off. They were randomly going on and off with my headlights on.
Fast forward to today. My windows wouldnt go down. Not just on driver's switch, but all switches.
I start checking fuses. Fuse number 38 I believe is one of the culprits. It was not under dash but under the hood. I swapped that bad fuse out and now all work except front passenger window. Not fro bits side or drivers side. Not sure if the brights are a separate issue or not but it sure is an interesting one if they are independent.
I'm currently working on boat and have limited free time and tools. Just have the little fuses and nothing else so can't get too far into it. I'll tell you it's annoying the heck out of me though I hate when there's an issue I cant figure out/get to. It just nags me to death
You think a battery would blow that fuse and do that? I think it's only 2 years old but will check it when I get home in a few weeks. Stranger things have happened that's for sure haha. That fuse was definitely bad but I did have dome lights and such in interior.Battery.
My SHO killed batteries every two years almost to the day. These cars esp do not like weak batteries.You think a battery would blow that fuse and do that? I think it's only 2 years old but will check it when I get home in a few weeks. Stranger things have happened that's for sure haha. That fuse was definitely bad but I did have dome lights and such in interior.
Haha gotcha. Well I've spent worse things on cars than a new battery before an Alaskan winter. I know this car sat almost a whole year before I bought it so I'll swap her out when I get home.My SHO killed batteries every two years almost to the day. These cars esp do not like weak batteries.
