Autox4fun
Kalamazoo, MI
Update, Finished doing another once over on the heads, Dropped them off for a Valve job, decking, and updated shimming. Back to waiting for the call they are completed. I will able to assemble the engine finally. Building to sell.... if you know of someone in need of a built engine.... I will post it up at when complete.....
810sho
Flint,mi
Rotational weight reduction
What machine shop are you using here In Michigan? Building an engine right now. Theres a guy up by me but I’d rather take it to someone who has balanced these rotatings, crank should be here within a week.
Do you happen to recall if he had trouble balancing the crank on the flywheel side of things, these don’t seem to be externally balanced, hope my new crank isn’t bent
the crank pulley serves as a harmonic balancer if that is what you are referring to.
Autox4fun
Kalamazoo, MI
I might just take it to them tbh, these guys do a lot of v8 stuff and older v6 like 3800s hopefully they can get it if not I’ll be going to the guy that did yours
810sho
Flint,mi
No, I think they just didn’t expect the crank to be that out of balance, they were questioning if it was externally balanced flywheel side. I haven’t heard back from them, so hopefully that’s a good sign
Autox4fun
Kalamazoo, MI
To do the balance, I provided the new crank, a flex plate, bolts for it, the timing gear, belt pulley and hard ware for that, and lastly - all of the new rods and pistons (which were also weight matched and modified. Also a used crank, old piston and rod setup for him to compare/understand ford's thinking. @810sho
This project is held up again by time needed for the heads to be cleaned up. Called on Friday to nudge the shop and remind them I'm still waiting lol. Being a project and not a shop calling due to a car on the hoist, I've been put on back burner. I nudge and said I have a deadline now and to bring those to the front.
Time will tell....
810sho
Flint,mi
Time will tell....
Hopefully everything goes well for you, it will be a riot of an engine, whatever it goes in. I also provided everything you mentioned besides the timing gear, in hindsight i probably should have. I called them this morning, and left a message hopefully they’ve made some progress over the week last week only time will tell
Autox4fun
Kalamazoo, MI
Made some moves tonight!
Great quality parts - sewing the manly and melling etc.... very cool she looks great and shiny.
