autoteleology
2010 MKS EcoBoost, about 85K miles. Started having a lean condition with misfires, eventually died while at a self-service car wash.
Here's what I've done so far to fix:
- Replaced all spark plugs, ignition coils.
- Replaced oil pressure sensor (got from Amazon, questionable if it was the correct part? It was in a bag labelled the right name, but the housing was light blue instead of white, and the socket size was different)
- Changed oil to 5W-30, changed oil filter
- Had PCM shipped off to Circuit Board Medics after faulty PCM diagnosis from independent and also a Ford dealership. Company said PCM was fine, refunded my money, returned. Turns out there was a blown fuse in engine bay (Fuse 47, PCM Vehicle Power 1). Great diagnosis, clearly.
- Replaced old battery with new AGM.
- Had LPFP and HPFP tested by shop, allegedly making good pressure
- Replaced all six injectors (VERY clogged with carbon) - some progress, now fires occasionally while cranking.
- 10/20: Replaced fuel module with Dorman OEM Fix unit, still no progress.
What is my next step? I'm honestly baffled as to what could possibly be the problem at this point. Maybe the cam phasers are failed / stuck open / screwing up due to the heavier oil weight? Maybe I fixed the real issue but got sent a mislabelled oil sensor? I don't think I have any timing codes, but maybe a misfire made me jump a tooth on my timing chain or something? Any opinions?
