M.J
What is the cause?...
Honestly no idea, which sucks because all my parts barely have 2,000 miles on them. Once I pull the engine and start tearing into it I'll have a better idea. I just know I have a crap ton of blow by.
yaycandy
Aerospace Engineer
Hanover, PA
What ethanol percentage were you running?
If you are replacing the motor, why not just put your go fast parts on that? Or are you just done?
M.J
Not sure I will need to check my data logs. I was running tunes between Matt from GH & Brad.
If my time and money allows, I'll be swapping engines to a not the original engine... I'll make a build thread once I acquire the engine & trans.
Ta2dResqr
Central Ohio
I got my TurboBay Stage 3 rebuilds installed this weekend. The seat of the pants feels quicker and sounds louder (especially on decel). I will go through a gas tank and then send data logs out. I was able to reinstall the turbos with TurboSmart Wastegates with the front axle still installed.
313tiger
