Bluezone
Ont, Canada
Started installing some parts for a little project that I'm working on. What a pita changing the coolant transfer pipe underneath the heads. I will finish it up tomorrow.
My next smaller project is to blackout the backup lights in the rear lenses. When I had the car tinted - years back - I light smoked the front lenses and rear brake lights - but for some reason decided not to do the backup light portions. Years later and different mindset - gonna use some headlight vinyl and smoke those portions out - will post pics when done.
RickyRecon
Northwest Indiana
Realized I hadn’t run the extractor down into the IC in a while (pretty sure not since I installed the noisemaker delete, and cleaned the throttle body…so, a WHILE lol) so I did that. With the drivers side jacked up I got at most a 1/2oz out. Throttle body is still clean as a whistle, and so was the plumbing between the two, so the UPR is doing its job. Nothing exciting, but figured I’d post here as a friendly reminder to check/drain yours once in a while. Bit of maintenance that’s relatively easy to overlook. Also a good opportunity to take a peek at the throttle body to see if it needs cleaning while the pipe is off. Just remember to disconnect the battery and/or the connectors if you’re going to stick your digits in there and move the throttle plate while inspecting. Safety third
Actually thanks for the reminder, plus I have to ditch the J&L and pickup a UPR catch can. I have never drained my IC yet. Any suggestions for an extractor?
Sent from my SM-T860 using Tapatalk
I finished my project - looks much better. Will post pics.
AzSHOluv
Prescott Valley, AZ
I did the same thing a few weeks ago. I've been meaning to post pics but been to lazy to wash the car first. I went with a 3m product called black duel color. We use it for sign face that we want black during the day and white (or what ever color leds) at night. I also ran a strip of it on the front led marker lights!
I needed wash the car too... she has to look good first.
Nova
US
Someone was selling their custom sub box made for his sho, so I had to buy it, and here's a little teaser picture. I'm going to take advantage of this long weekend and try to get everything wired up.40b15daee6a494df42b3cbbe4274af42055ee685e589dd492ae8f7792605f743
Sent from my SM-S918U using Tapatalk
Someone was selling their custom sub box made for his sho, so I had to buy it, and here's a little teaser picture. I'm going to take advantage of this long weekend and try to get everything wired up.View attachment 87225View attachment 87226
I am soooo jealous
RickyRecon
Northwest Indiana
Can’t go wrong with a mityvac.
Yeah, to my knowledge the UPR is the best bet for our cars. It’s not cheap, but personally I don’t mind paying a premium price for a product if it actually works well. You’re definitely going to want to get the upgraded check valves too
My J&L catches nothing, some moisture, just small dried up drops. Crapola. UPR is 15 minutes from my home.
Hopefully, after I'm finished, you'll be even more jealous lol.
My stereo is 2nd on my list. Need new rims, then tires. Then redo stereo. Please keep us informed of the equip you use. Thanks - and I will be very. Still running the sony premium crud.
Nova
US
I'm only adding 2 10" subs. Everything else will still be stock Sony stuff. Maybe down the road, I'll change out some more stuff.
Nova
US
Here's a quick little update for you, @kryptto. I have 2 Alpine 10" subs wired to 1 ohm, installed in the box and I have the box mounted and secured with 2 brackets I made myself to make sure the box doesn't more during spirited driving. 72d99294409b04457dc40b753cfcac96688f553c6aa929844437717b9dd9c67d
Done, the lights are fully tinted however with the sun it's hard to tell.
2014 Ford Taurus SHO PP - Catless Downpipes - 3BAR MAP - Ford Performance Spark Plugs Colder Range - K&N CAD, Reisch 170, HP Tuned, Accel Coil Pack, Chrome Delete - Android Auto Nav System
Nova
US
Looks good! When I did mine years ago, I had it fully blacked out like yours but then wanted something different so I cut out the clear parts of the lights so that only the red parts of the lights were blacked out.
Mine have dark tint on them.View attachment 87240
I like your darker tint - when I had the lights tinted I went very light grey, sided on not causing others to say they couldn't see my lights.
Thanks for sharing.
