Sho stalls and won't start when hot
psix
mars
Hello everyone! I replaced the crankshaft sensor, cleaned the connector on the camshaft sensor, it didn’t help!
When hot, the craving disappears, it stalls, it’s hard to start, I’m attaching a video. Thank you!
Majestic
Do these use a TFI like the SVO, Turbocoupe, etc had? Those would cause the same issue, especially if not installed using thermal paste.
Yes they do.
Do you have the ability to get the codes from the computer? This will help narrow it down.
Irish Pride
Irish Inside
MusicCityUSA
Pull codes and see what comes up.
If you want to throw a part at it, swap out the DIS module with a known good one and some fresh heat sink.
-Chad
psix
mars
-Chad
I tried to change the dis, didn't help.
How to read codes please?
psix
mars
I checked the dis module and applied the paste, it did not help.
What year is your car? early have 2 digit and later have 3 digit codes
You can check it with a paperclip and count dash light flashes here
If you have difficulty getting the counting right (happens alot) this code reader has come in very handy. You can use amazon and also probably find it locally at a parts store
psix
mars
Thanks! I thought I'll figure it out soon.
psix
mars
Today I cleaned the masses of everything under the hood, checked the fuses, turned off the sensors one by one, the throttle valve, air, temperature sensor, until nothing helped, even when it is cold it can not start.
Blackdr16
93 SHO
Washington, Illinois
Different direction here... have you checked fuel pressure? Baseline reading? If it changes when it's hot? I once beat my head against a wall as my fuel pump slowly died.
or you could check the codes. Cleaning sensors is not going to get you there except maybe cam sensor. I would look at IAB/IAC for the funky idle. Dead tack can sometimes be a cam sensor. It would be best to check the computer codes to help yourself
that message is on lather,rinse, repeat
You will need to know how to do this going forward. This old bucket will have other problems pop up.
FastCAD
Miami, Florida
u mentioned that when "when hot it stalls and is hard to start". Does it start when cold? Do u have to try many times to get it to start at all? If so it could point to the cam sensor. Unplug the cam sensor (when cool) try to start (it may take up to five times) the ecm will go through differentt firing orders to get the start up. If it starts then it is the cam sensor. Black round sensor left rear eng. block below the intake manifold facing the pass. strut tower.
psix
mars
Yes, I looked when it didn’t start, the pressure was good, because there is this thing on the ramp, then a friend suggested that it could soar brains, a temperature sensor on the ecu, I’ll try to turn it off
psix
mars
I climbed to it, the plug was green, I cleaned it, the sensor itself was removed, cleaned and assembled, until it helped. I'll try, thanks!
psix
mars
Friends, after a long dance, I decided to check the fuel pump, when the car stalled and would not start, I knocked on the tank and after it started, so three times. I bought a new pump, changed it, left in the evening and in the morning again this garbage, stalls.
I haven’t measured the pressure in the rail yet. There is an error in the EGR, I looked for the valves, I didn’t find where they are? Maybe someone has a manual in pdf for sho or where can I download it?
Then I found out about the sensor from the steering rack to the ecu, can it give such symptoms? For four contacts which. Of course, there is another option that the bad pump is new, but I'll check it later.
psix
mars
I have a jumper on the clutch sensor, now I understand that this can be a hindrance too?
Blackdr16
93 SHO
What was your codes?
The clutch sensor is unlikely, it wouldn't cause it to die. It would only cause a no crank when trying to start as the pedal has to be depressed.
Get codes, check grounds. Likely something that is failing when heat or foreign matter is introduced (oil, water...)
Would recommend getting yourself a fuel pressure gauge just to know you aren't loosing pressure at the rails (again faulty ground, bad ECU, pump issue...all of the above). You'll find having it in your tool arsenal handy in the future even if it isnt a cause of this issue.
Many of these issues are found by eliminating possibilities. Codes are easiest and most accurate. Next is running down the list of verifying things are within expected parameters. This is why you'll want test gauges, multimeter..etc. I wouldn't purchase and replace any parts until verifying something is bad. (Most of us now have a box of various spare parts in the trunk thats grown over the years, makes some troubleshooting easier)
psix
mars
Man, after reading this topic, where the control module reads information from the clutch sensor
Codes
33
172
176
214
528
542
I have one fuel injector disabled, you need to remove the manifold to connect it back, perhaps because of this 542
