Power loss while accelerating
Kyledubya
Missouri
I have 2012 sho when accelerating will drop out and kick back in. It’s not a transmission issue but similar symptom. As you push down the gas pedal and begin accelerating it will lose/drop out it’s power. There are no codes thrown, ever. I’ve replaced fuel injectors, coil packs, o2 sensor, plugs, battery, alternator and had a mechanic run a full diagnostic on the computer.. nothing comes up bad or faulty. Also had the computer recalibrated. 3 mechanics have thrown their hands up to me. Can anyone help?
Bill Bourgeois
Nevada
I'm having similar problems with hard acceleration when accelerating to pass. Engine misfiring but no codes. Could it be the fuel pump or bad gas?
FREAK_SHO
Wisconsin
Is it a miss fire or a boost dump? Check the zip tied hose, if that isn't the issue then check all piping for leaks.
