I have been experience issues shifting on my SHO
I end up driving back home which was less than a mile away while without using the clutch and my gears didn't grind when I shift gears, I had to turn off my engine to put it in reverse to straighten up my car at my home and the weirdest part is that my shifting started working again
- Couldn't change gear with the clutch pressed down
- it kinda felt like the clutch cable broke when press the peddle but I checked the cable and it's not broken
- the peddle felt easy to press
- my car would start moving right after I start the engine
