Mike67
So what is everyone seeing on their boost gauge for GH's AO tune? I have his Gen 3 turbos, GHIC, PPE catted DPs, XDI-35, Airaid CAI, MSD coils, and GH powerpack.
It's been a good long while since I had that tune loaded up but pretty sure it's like 17-18psi maintained on e30 GH Gen 3 tune. Because the boost doesn't taper off in the top end you gain a bunch more power up there and the more efficient turbine flow frees up power also.
Because it's enough for 500awhp ish and nice still on the motor17-18 psi with upgraded turbos? lol why bother
What is your OAR? anything lower then -.96 is less boost. so if its -.96 then do a log and look at WGDC if it's maxed at 100% then you have a boost leak should be closer to 70%. the other thing is look at the boost reference hose (5/16 size) in the middle of the motor to the center crossover charge pipe they like to come off if you haven't clamped it.
I only run Shell premium? What do they need to be at? Would a gallon or two of E85 really help? What’s weird is the first night it ran really well.definitely need to get that OAR up, sounds like you got some bad gas...
Compress it as a .zip then you can attach.I've tried to upload the datalog but the forum doesn't like .csv files
In the meantime, am I reading right that you just loaded the base GH AO that you got with your livewire and not a file specifically for the upgraded turbos?
