What boost levels are people seeing with the GH AO tune?
Boochy47
Michigan
Will one of you guys post a video of your gauges when you’re driving not in sport mode I wanna see how your orange gear counter looks n runs
Boochy47
Michigan
Is that all? Assuming a true E85 fuel and a 93 octane fuel (no ethanol), I calculated you would need to use 5.29g of E85 and 9.71g of 93 to get 15g of E30. Using this calculator, with 5g of 108 fuel and 10g of 93 fuel, it says you should have 98 octane.
http://www.serioussolutions.com/evo/octcalc.htm
Premium contains 10% ethonal I think don’t it
I only run Shell premium? What do they need to be at? Would a gallon or two of E85 really help? What’s weird is the first night it ran really well.
Damn I used too run only Mobil 93 but lately I’ve been using sams club 93 with speedway 85 but I only run 85 every other tank but now I’m really wondering who has best gas I always thought Mobil damn I ran shell in my supercharged SS way back when tho
yaycandy
Aerospace Engineer
Hanover, PA
I got it pretty good for perfect e30. Pumps usually see e70-75 and 93 has e10 right on the money and ive checked at least 10 times different stations at different seasons.
I use Wallace racing calculator as its better than excel macro and others.
Right at quarter tank left line i add 5 gallons of e85 and the rest of 93 and im right on e30-e29 all the time.
I think people assume e85 is true 85 and that gasoline has 0 ethanol. And get their calculations off.Most states it has e10 even if it dont say so on the pump. Even down to jerja ive checked and in Pa where my car is stored and in NY and states inbetween NY and Jerja. All the same
Majestic
Shell premium around here claims to be ethanol free. Too bad 91 octane is as good as it gets.
Ta2dResqr
Central Ohio
That is why I put "(no ethanol)". If you go to marinas or select gas stations, they sell straight (0% ethanol) gasoline.
The Speedway fuel is actually higher quality (albeit lower octane) than the Sam's Club fuel. Out of the three options, Mobil 93 every tank would be the best answer.
SHOthyme
MN
Ours usually switches to e83 over the summer, but not this year, it was a steady e70 all year long.
I use e85 mix calculator app on android and double check it with my fuelit, I also have the fuel gauge pid on my livewire so you just plug in all of the variables, then you're off to the races. (pun intended)
If you can find e70 and e10, then it's a pretty easy ratio, it would be 2:1 at that point to get to e30 as long as you already have e30 in the tank. If they change it to e83, I can always tell on the fuel it, because then I end up at e35 after a couple of fills which is fine too.
SeanDev
Yep and the Meijer gas station I use for some reason when it comes to fall or winter it changes the E85 to E75. I've test every time before I fill.
SeanDev
Have your tuner turn it on, AJP does it without even asking, he just adds it to the tune.
markmoomnu
