Yikes dude, your boost control is all over the place.The file is specific for all my upgrades to include the turbos. I received 2 complimentary tunes one for buying the turbos and IC. AO and E30. I still need to buy a fuel line to instal the ethanol sensor.
Thanks for your help!
No, but that's about to change based on zero response from two emails sent to them. I'm disappointed, especially based on all the good reviews I've read on here. I'm assuming I can use the SCT LivewireTS to load other vendor's tunes.So no other tuner out side of Gh?
Yes. other than LMs but you don't want to go down that road!No, but that's about to change based on zero response from two emails sent to them. I'm disappointed, especially based on all the good reviews I've read on here. I'm assuming I can use the SCT LivewireTS to load other vendor's tunes.
You need send this to matt but I bet you will get the "check for pipes touching, knock wires chaffing and add 2 gallons of e85.
put it in 5 or 6th gear in sport at low rpm plant the peddle and let the KR go to -4 or better this will bring up your OAR. you can set this on your livewire to display KR and OAR.
In my experience with his shifting you need to stay out of 1/4 to 1/3 throttle without having a load on it (more aggressive with the peddle) it seems the enrichment with low load at this point bring the KR+ in and then drops the OAR fast.
remember your tuner is the FIRST place to send logs and questions! and he is good for replying.
you WG was a roller coaster ride but with the bigger turbos and lower boost I wouldn't expect anything less.
Looking at your logs, I'm not sure you'll get much better with another tuner until you get the fuel issue taken care of. The tune is doing exactly what it's supposed to do based on the fuel quality, you should notice a vast improvement in both spark and boost as you improve fueling.
I'm not following you with the fuel issue? Are you saying you think I bought bunk fuel at Shell using the V-Power? I've been running it since I bought it 3 months ago and never felt like I've had an issue.
Or are you saying that I have a fuel delivery problem? It has a new XDI-35
Well, not sure if you gave Matt enough time to respond. I dont have a GH tune so not sure what his average response time is but if you're looking for quick response, Brad's not your guy. I won't tune with anybody else but him, but he can take some time to get a response from occasionally.I sent all the logs to Matt and GH ales emails LAST NIGHT and another email asking if they figured out what was going on. Sounds like I need to swap out the XDI35 and 3bar back to stock and reload my stock tune and look at getting a tune from Brad.
I sent 2 additional datalogs late last night.
But you only gave Matt 1 day? He's a busy guy im sure and I'd like to say he may not have gotten to it just yet. There's alot going on in the car mod world and things are moving slowly across the board these days.
I've had nothing but positive interactions with Matt when I have spoken to him. He's highly recommended...I'd give him a bit more time than just one day.
Well I need to eat crow, he replied about two hours ago and my damn email wasn't updating for some reason. He said bad gas also. I just thought Shell V-power wouldn't ever be ****** gas. I sent him my stock data log.
I guess I will be draining my 3/4 tank of gas and putting it in my van that won't know the difference. What a PITA
I probably should have called them today, if my email was one of a couple hundred. I would think that he has someone filtering the emails and prioritizing them. I did a stock datalog but the config file for the SCT Livewire doesn't have KR. Is there a way to add it? I was able to boost to 12psi and it felt a lot stronger on the top end.
Does anyone have a good datalog config for a stock tune? I'd like to see if I'm getting any KR because if I'm not that eliminates bad gas.
Thanks for everyone's help
Emailing me is the best correspondence and if you email me on a Sunday and Monday, I only usually reply in the evening Monday when I work on this stuff. Until we figure out why it is so unhappy with the fuel or whatever else is causing the low OAR and KR at wot, it isn't worth troubleshooting anything else that needs tweaking. StripSHO has some bug up his butt with me and tries to show everyone what a better tuner he is in all the forums to make himself feel better about the life choices he has made I guess. StripSHO has done nothing to further the platform, and only tries to find problems with what everyone else is doing.
My apologies for not being more patient (I probably should have called mid-day to let someone at GH know of my issue), I originally got on here to try and figure out what to look for as far as boost leak and to sort out what could have been wrong with my reassembly of the car after the install of numerous perf parts and the solid trans mounts. I had the mounts in and out and no change. Before getting on here I did the usual: look for loose boost pipe connections, any exhaust connections or hitting on something, all electrical and vacuum connections, wastegate vacuum connections (they usually result in over boosting with a single turbo, but with twins I thought that maybe one was over boosting and the other was compensating), I didn't think of bad gas because when I loaded the tune Thursday night it ran like a ***** ape and boosted to 18-20(20 for just a second on initial boost) and I had under a 1/4 tank then filled up on Saturday so two different batches of gas over a week between fillups but the same station.
I put the stock HPFP, Map, and tune back in the car late last night and did the data log with the canned SCT config. Can I use the config file that you sent me for the next data log? I'm using it right now so I can now see the boost and KR big dial gauges.
Another question is can I do multiple data logs with the SCT before taking it to my PC to upload them or just one at a time like I was doing? In the directions I thought I read just the last log would be available.
