Michigan-SHO
Get rid of any rough castings with some porting
Do the Raptor camshafts work in our motor?
Okay here's a question for all you gear heads that are rebuilding Engines. What can I do when rebuilding an engine to get more horsepower out of it? the guy at one shop can shave the heads or something for more compression? can you guys give me some ideas so what he can do..
You can build it to handle more power for sure. Manley rotating assembly and raptor crankWhat about internals crankshaft, Pistons can any of those be modified or changed out? The guy is going to build me a motor might as well see if I can get some horsepower out of it
I only owned a factory s/c vehicle that I did little to modify. I'm not sure if higher c:r is better or not for engine power vs stock c:r if you are fighting preignition. Tuning may make this doable but I'm just asking for those that are fighting with fuel octane and knock if this is better or not in this setup.
I don't know THIS motor...but generally, on a turbo motor, you want lower compression, in order to maximize boost without getting knock...unless you run race gas.
This usually means using dished pistons.
That's about all I have to offer. Primary ways to increase power are, higher rpm, higher displacement (bigger turbos), or higher compression.
Okay I'm so ****** confused mine is a turbo motor Why are some people using Raptor cams and other parts?
YouTube clickbait? To brag at car meets?Okay I'm so ****** confused mine is a turbo motor Why are some people using Raptor cams and other parts?
Short block is the bottom end, no heads. Long block is complete with heads.
long block will typically be complete minus intake manifold and other components like alt, water pump, and so on.
Welcome aboard
