Upgrade to SYNC 3.4!
SHOthyme
MN
Yessir, definitely like the all blue theme. The one thing I really want....is the volume to go 0-100
It is weird that it doesn't go to 100... JUST LIKE THIS MESSAGE IS FOR ME... yup, that's right I just hit message 100 I didn't realize it would feel so good!
COMpulse
Detroit Area
Did the update last night, didn’t go so well.
2016 SHO original SYNC 3.0 with navigation.
First, let me say the video and directions were spot on and I had Zero issues with this part.
However, I forgot to click the navigation box during the install process so right note I have no navigation. This should be fixed today when I download the correct files with the navigation
Problem number two, my USB ports in my center console no longer work, the error code says they are not supported. Further inspection reveals later 2016 models and up have a different USB port that supports Android auto and Apple car play.
Lastly, my clock is now 4 hours ahead and I cannot change it. I can move the numbers but in about five seconds the time blinks back to what it was before.
Good times....
Just finished this up.
My clock was off by 4 hours as well. I went into clock settings, and Sync with GPS time, and now it's accurate.
Next up is turning the Nav repeater on for the IPC in Forscan if possible.
(I'm on a Sync2-to-Sync3 retrofit, with the updated USB ports, GPS antenna, etc)
Edit-
Well the navigation on the IPC just worked without any Forscan changes. Neat.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Edit-
Yea I noticed people saying that it automatically applied it to the IPC now.
SHOthyme
MN
Put the Google on Ford Navigation IPC, one of the first videos that pop up, gives you the best description... I had to do that too. :)
SHOthyme
MN
It was cool watching them go through the selections... now I want to try it.
Michigan-SHO
Michigan
I was able to complete this upgrade last night by doing a downgrade then reinstalling the upgrade. I now have maps again, along with the correct time.
I do not, however, have all the fun options in the IPC Navigation page that I have seen in YouTube videos.
And I still need the new USB hubs and trim cover. Because of this my USB hubs don’t work and I get an annoying message on start up.
COMpulse
Detroit Area
The IPC Nav info only comes up when you have a destination set through Sync Navigation or Android Auto. It won't show anything special just sitting in the driveway until you start driving.
It's slightly more useful than the AWD gauge. Slightly.
SHOthyme
MN
I dig it when I'm navigating, I like all the info it gives you, without having to look over at the big screen.
