FiveLeeter918
Ortiz Performance Sales
the gen 2 changed the game. Even the regular F150 eco is killing it
Don't forget the larger fuel pump, the additional variable exhaust cam, the better heads, and Google the rest if you want full details.
Is it too early to start a bring back the SHO thread?
And add in make it rwd biased and with the raptor motor/6 speed manual and make the interior more like the fusion/focus.
If you were gonna go through all that you might as well make it dual Tesla motorsA dual engine, SHO in the front, Raptor engine mounted in the trunk frankenstein project.
with a trailer hitch to pull the extra battery packIf you were gonna go through all that you might as well make it dual Tesla motors
Without having gotten into deep research on this...you might be onto something....I wonder what's involved in programming the 8f57 for our shos. little higher tq handling capability Than the 6f55. 2 extra gears. Bolts right up.connector is the same.
I like it!Without having gotten into deep research on this...you might be onto something....
The only common transaxle issue Ive seen personally is the snap ring issue that has nothing to do with torque or HP. I have yet (despite seeing the question posted multiple times here an EBP) to have a specific failure pointed out when you put a lot of power through the 6F55.
It's generic to say transaxle failure, we really need to know what the weak link(s) are. Torque converter, specific clutch pack, drum, gear set, case. Not that there's much aftermarket support, but some of you are willing to put the time and $$$ in to see how far things can be pushed. Does anyone know factually, what parts are breaking internally?
Good memory man!Mike Bambic's trans failed on his Flex.
Is that who you're thinking of?
Good memory man!
Yeah I remember that happening, but was it ever diagnosed specifically what the failure was?Mike Bambic's trans failed on his Flex.
