Which brings us full circle, insomuch as the HP # I was provided back in 2015 (which was/is "around the 720 mark".
To which when I asked for details therein, I received the polite, but terse *** smile.
LOL.
An engineer has to bring data for anything he states in a meeting where decisions are made about part strength. If you can't answer the question "where is your data?" you might as well not go into the meeting. Data is obtained from breakage drives, lab tests, the Metallurgy lab, the Heat treat lab and more. Hopefully, not a field return! Often, a suspect part will be swapped into a transmission or drivetrain. It could be a gear that has a certain depth of case hardness or a certain metallurgical characteristic, and they will try very hard to break it just to see if the math and physics were solid.
A good engineer can predict within three parts of what will break if you go over the torque limit for the given transmission. That torque number has data driven street cred!
Shoblock
