Forged Internals Build 10:1 vs 9:1 compression pistons????
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
I'd love to see one of the maps for the ATPs to compare. Any way you can work your magic getting those? LOL...
Haha! I didn't have to look too hard for those of Matt's turbos. I saved those attachments to my phone when he released them on EBPF.
Originally if we wanted turbos it was only ATP for options. Then Matt came along with his. At the time of purchase, it seemed like all of a sudden...unbeknownst to me....issues with ATP's turbo smart wastegates surfaced....ppl saying they're finicky. So I decided to buy GearHead Turbos. Matt's flow 30% more. ATP are more powerful but so far not myself or anyone else I know has even come close to maxing GearHead Turbos. Plenty of power to pop the motor. And slightly cheaper.
I’d go more compression and less boost.
I have done that before and if works great, however you have run a dedicated fuel for that setup. For a racecar is is great, for a streetcar is really hamstrings you. That is why I am a huge E85 fan.
mrhighcaliber
10:1 seems makes the most sense from every thing I've read here, and the outside research I've done.
Better drivability and More power on less boost are the most appealing benifits to the stock 10:1.
Direct injection + E30 + meth spray would seem to make detonation almost a non issue up to my target 18-20psi.
9:1 pistons for the sake of experiment, is still tempting for me, though I'm convinced 10:1 is the way to go.
Ecoboost_xsport
Sacramento, CA
That first one severely hurts my brain. Is that supposed to be stock turbo, and the gt25 is the one Matt sells?
Good question. And as the ATP is a Garrett product, I've been trying to nail down the equivalent Garrett turbo nomenclature but cant get a definitive answer. Using their naming convention, I was getting something like a GT2256 but not sure that's accurate
802SHO
The one with the GH logo is the stock turbo. You would think the GH logo would be on the one they developed.
stripSHO
Idiot Savant
Detroit
Yeah I don't know how that little sketch was derived but I wouldn't put any faith in a drawing that doesn't have any choke points. I realized last night that I can actually build a stock map from the turbo flow models within the ecu. I'm going to try drawing one up after work, using Ford's data. I'll post it up in a new thread so as not to hijack this one.
My impression was that the few drop-in options available all just squeeze bigger wheels into the OEM housing, which make them GT15's still, no? Which really throws me off as to why a GT25 map is being passed around. I know squat about turbo model nomenclature though.
StealBlueSho
NA
I would ping BPD1151 before making a purchase as he is having a new built out from very knowledgeable builder... the lower compression seems interesting... and I don’t know a single SHO that has gone that route...
StealBlueSho
NA
Personally haven't seen anyone have a benefit for 9:1 on these car. a high horsepower v8, sure. but I don't think you'd ever see enough power to take advantage of a 9:1 compression ecoboost engine.
Who has gone with lower compression on these cars with a rebuild?
Ecoboost_xsport
Sacramento, CA
Ryan over at RMB Motorworks is an ecoboost mad Scientist, he can provide clarification as well. He's the one doing my build...
Sent from my SM-G965U1 using Tapatalk
StealBlueSho
NA
Yup... Matt Robinson has been telling me send my motor there for a year... lol
My response is I’m not building a motor until I can build a better awd system and trans to handle it.
Ecoboost_xsport
Sacramento, CA
I can't be mad at that, lol...let me know when you do, I'll throw money at you haha.
It is pretty simple....F150 10 speed and rear end swap. Super easy, barely an inconvenience...lol.
Zpak
Es Aich Oh!
The region, Indiana
Has anyone actually measured to at least see if the 3.5 would fit in the engine bay in the correct orientation? I don’t see width being a problem but depth is another story.
StealBlueSho
NA
I have a partial quote for a rwd drive conversion on the SHO with an LS setup which is cheaper than the F150 hardware minus the electronic bits....
The shop called me back after a couple of days after they hit $40K in fab labor / regular labor and parts..
I said we can pull the plug...
Biggest issues were gonna be mounting a rear end that could handle the torque. Custom mount points, custom bracing, custom axles, brakes, etc etc etc...
So it would be easier to body swap a F150 you are basically saying?
crystizel
