802SHO 2010 Build
I had a talk with Chuck about my car. It was pretty dead on with numbers and the analytics made sense. It is a nice tool going forward.
DadMobile
Texas
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
One thing I’ve learned from all the diagnostics I’ve done on this car is how valuable negative test results are. A test doesn’t have to prove you’re right to be useful. Every failed theory narrows the list of possibilities until eventually all that’s left standing is the truth.
That’s where I’m at right now with the tuning.
Ryan’s current theory is that there is something in the OS or strategy that is causing the PCM to intervene. The logs repeatedly show the throttle closing to maintain roughly 368 lb-ft brake torque and the Torque Source reporting Engine Speed Limit. He’s already escalated the issue to HP Tuners engineering, which is exactly what should happen when you start running into behavior that doesn’t make sense.
At the same time, I’m not ready to conclude the OS is the problem without testing other possibilities.
A friend of mine, Brendan, just a solo/private tuner from Canada, has been tuning his own MKS for several years and has spent a lot of time working with the torque model and inverse tables in HP Tuners. His approach was never based on calculators or theory alone. He made small changes, logged the results, kept what worked, threw out what didn’t, and eventually landed on a torque model that allowed his car to report 580+ lb-ft brake torque and over 60 lb/min airflow. He also pointed me toward another SHO using the same ECU family that reports 600-650 lb-ft brake torque without issue.
That immediately raises a question. If another Green Oak car can calculate and report 600+ lb-ft brake torque, is there really a hard 368 lb-ft ceiling in the OS?
Maybe. Maybe not. So instead of arguing about it, we’re going to test it.
Brendan reviewed my file and a few things immediately stood out to him. Keep in mind he doesn’t work for a shop, follow specific guidelines or protect a brand, the biggest one was the inverse tables. Some of the values in my current calibration are scaled so aggressively that the math suggests the engine could make torque numbers that are nowhere near reality. His opinion is that the PCM may be seeing torque and airflow relationships that simply don’t make sense. If the model becomes unbelievable enough, the PCM could be defaulting to a factory safety strategy and pulling everything back toward the stock 368 lb-ft area because that’s the last place it knows how to operate safely.
That is only a hypothesis. Ryan’s hypothesis is that there is still a limiter or strategy issue in the OS. Brendan’s hypothesis is that the torque model itself is causing the PCM to trip a protection strategy.
Both theories are reasonable. Neither has been proven.
So the plan is, Brendan is going through the file and changing the things that stand out to him based on his experience. We’re correcting tire revs per mile, cleaning up parts of the torque model, adjusting some pressure control logic, setting the car up for a true 0% wastegate duty cycle baseline, and then running the exact same road test again.
The result is informative either way.
If the car still hits the same wall, still reports Engine Speed Limit, still closes the throttle and still parks around 368 lb-ft brake torque, then Ryan’s theory gets much stronger.
If brake torque climbs naturally, the throttle stays open, and the car behaves differently, then we learned something equally valuable and Ryan will have another piece of information to work with.
Either outcome is a win because it replaces assumptions with data.
At this point HP Tuners engineering is looking at the issue from one direction and Brendan is helping me look at it from another. I’m not interested in proving anyone right or wrong. I just want to know why the PCM is doing what it’s doing.
Same road. Same hardware. Same 0% duty cycle baseline. Different model.
Let’s see what the car says. When the rain stops the model diagnostic test starts.
802SHO
I absolutely love this. Instead of one guy waiting and one guy looking….there are 8 eyeballs looking at this and I now have access to the model through my friend Brendan. The logic makes sense, the changes are understandable the test is strictly same road same % duty. That’s low risk. And I like that it’s 70% still Ryan’s file bc it would prove he’s been mostly right.
In diagnostics you eventually land at a place where you no longer are emotionally attached to results. You still prefer a result but the test result is all you want. True or false let’s find out the truth.
802SHO
IMG 0094Is this A) Operating System that needs a limiter exposed
OR
B) Operating system triggering protective logic bc the calibration contains errors?
The car will vote next. As soon as it stops raining for F sake.
This type of diagnostic test is exactly why I own a new TRS and valve body/ solenoid assembly sitting on a bench instead of in the trans. No test is worthless…not even a triple check.
802SHO
Has anyone else gone this far into talking about tuning? Just a random thought.
My final analysis of this situation is that this upcoming test is going to answer a lot more questions than just whether Brendan’s theory is correct or not.
One thing I’ve learned over the last year is that sometimes the answer you’re looking for isn’t the answer you get. The value is in the information. Every test narrows the possibilities.
This test is going to answer several lingering questions that have been sitting in the background for a long time.
The obvious question is whether the torque model itself is causing the PCM to trip a protection strategy. But there are other questions hiding behind that one.
One thing that has bothered me for a while is how difficult the car has become to fully relearn the Knock Octane Modifier (KOM). SCT calls it Octane Adjust Ratio. HP Tuners calls it Knock Octane Modifier. Either way, the concept is the same.
In the past I could consistently get the car back to -0.96 fairly quickly. Usually 8-10 minutes of loaded driving and it was there. Lately I’ve spent 30+ minutes trying to get it to fully relearn and have never been able to get it all the way back. The highest I’ve seen recently is around -0.64.
I don’t have to wonder anymore I can look. Having access inside the file is where guessing gets replaced with answers.
One thing Brendan immediately noticed was that Power Enrichment was delayed until roughly 70% throttle. Power Enrichment is the point where the PCM transitions from stoich operation into a richer commanded fuel mixture under load. That richer mixture helps cool combustion, increase exhaust energy, spool the turbos harder, and gives the PCM more useful information about what the engine can tolerate. Brendan’s position is that 70% throttle is extremely late for a turbocharged application. His preference is closer to 30% throttle.
The logic actually makes sense.
If enrichment doesn’t occur until 70% throttle, then unless I’m essentially going wide open throttle the PCM isn’t spending much time in the operating range where it can aggressively learn fuel quality and knock tolerance. Looking back, that may explain why KOM has become so difficult to fully relearn. I shouldn’t need repeated WOT events to get there. Historically I never did. Moderate load and moderate throttle were enough.
So now another question gets answered: Will earlier enrichment help the car relearn KOM more quickly again? I genuinely don’t know, but it is a testable theory. Another lingering question is whether this setup is really as different from a normal SHO as we originally thought. When the car was fighting voltage issues, BOV issues, fuel pressure reference issues, electrical problems, and a handful of other mechanical problems, it was very difficult to know what data was trustworthy. When the hardware isn’t behaving correctly, confidence in the calibration naturally suffers too.
Now that the voltage is healthy, the BOV is working, the fuel system is behaving, the grounds have been corrected, the relay issues have been corrected, and the hardware has proven itself capable of moving serious air, I’m starting to wonder if this isn’t some alien calibration that requires completely unconventional tuning. Maybe it isn’t that different.
Maybe it still behaves like a Ford Green Oak SHO PCM wants to behave, but it needs believable airflow, believable torque, believable pressure relationships, and believable vehicle speed information.
In other words, maybe it is fundamentally still a SHO calibration, just scaled appropriately for a combination that moves significantly more air than stock.
That’s why I love this test.
It isn’t simply testing whether Brendan is right. It’s testing whether a healthy system combined with a calibration that more closely matches reality changes the PCM’s behavior.
Does brake torque finally climb naturally?
Does the throttle stay open?
Does the car stop falling back toward 368 lb-ft?
Does KOM relearn faster?
Does part throttle improve?
Does the PCM trust what it’s seeing?
Or does it hit the exact same wall and strengthen Ryan’s OS theory?
And I love that I don’t need to check with anyone to see if it’s ok to run my test. I’m not helpless and that feels great even if I end being wrong. That’s freedom
DadMobile
Texas
It’s unfortunate that after all this time and money it still doesn’t want to shift. I think after some more time and money the car will shift right. I wonder if changing out the PCM would solve these issues? With everything you have done -a custom PCM seems like a logical solution.
Being that this is going to be the fastest EB car on the planet, do you have plans to install a roll cage?
802SHO
I don’t care if anyone likes seeing what Chuck says, it’s so true. The results of this test are going to hand the truth a microphone.
IMG 0219IMG 0225IMG 0222IMG 0223
Tomorrow we learn some truth.
802SHO
Car felt better but hit the same wall again. 368 desired brake torque. Butt dyno liked it but the log said otherwise. That was the first good feel that did not come back supported in the log.
Car made 49 lb/min. 1.8 load but like a fly, flying into the same windowpane…we hit the glass wall again.
I initially slightly celebrated lmfao…and then took pics. IMG 0245IMG 0247IMG 0249IMG 0250IMG 0251IMG 0254IMG 0257
And then saw the same limit. Damn.
Low-mid throttle felt better and low speed shifts felt crisper ….the hit it felt like a delay but went pretty well…I thought it felt cleaner. Resetting KOM didn’t seem to work and early enrichment wasn’t really working.
It’s just weird the butt dyno liked it the best so far.
Back to my own drawing board while Ryan waits to hear from HP.
802SHO
Ok an update. I’m thinking to use Forscan to do a crank relearn and KAM reset. Then retest Ryan’s ReV8 file. Turns out Eric Brooks, the lead Ford Engineer and developer for HP is the one who has my file. That’s pretty awesome. IMG 0282IMG 0283IMG 0284IMG 0285
802SHO
Last night was a partial success. The forever revolving door of checks and tests. Full circle back to the crank relearn process. I gave up too easy when I found for my OS in HP, VCM Scanner doesn’t list any special vehicle functions for me. Until I realized…oh yeah I can use Forscan…which is likely better anyway…
Yeah….this procedure carries real weight. Just read what the criteria is. IMG 0294
-built engine
-new crank sensor
Those 2 are perfect reasons. IMG 8BC9241B 4127 4136 9A37 866DE650FC48IMG 282EBF84 B794 4BEE A7B9 41174CF1A7F0IMG 0298IMG 451B51DB 1A53 46B5 B018 6E2CBECA01B0IMG 4BABB7E3 9DAD 4C18 8E3E 9480B1914931IMG FC671FFF 18D8 44A3 AA41 65C44FD46267
Yes…….essentially I introduced the PCM to the literal engine in the engine bay for the first time and then wiped the PCM’s learned memory.
And the car instantly rewarded me. Low speed, low load-moderate load shifts? Synchronized! Clean! Exhaust note? Crisp like as if before it was mono now it’s in Stereo. Drivability restored. And it felt spicy doing moderate stuff. I was trying hard to stay objective but every time I had to come to a stop and go, every time I gave it a little it consistently rewarded me.
It didn’t improve a few shifts, it improved every shift. It felt coherent, it felt drivable. It felt synchronized. I even got a taste of one of the most beautiful mechanical moments, a 2nd gear downshift from 3rd as I was slowing down and it felt like it was perfectly rpm matched…like butter. No joke I went from guarded but happy…wondering if it would mess up once or twice to…relying on it to be perfect and it didn’t let me down.
I was pumped! I thought this might be it. I took off to my log road hoping that engine speed limit was resolved. And at this point I’m learning what it feels like to hit that limit.
I can feel it go flat as I floor it. It did the same thing, flipped immediately to engine speed limit and throttle kept the car to that glass wall of 368 brake torque. But man…it shifted cleaner and I actually let out bc during 4th throttle came back. When I let out the exhaust did one solid CRACK and it felt and sounded great.
I wasn’t sure what the log would show but drivability felt like it was BACK. This was the absolute best it’s ever felt since the new build. It was just in sync…that’s all I kept coming back to. It just felt off…now it feels synced. That crank relearn was absolutely needed and the car fit the criteria perfectly.
Sent the log off to Ryan. One more log now with crank relearn and adaptive tables reset. Just more evidence. But like I told Ryan……it’s enjoyable to drive now. Even with it the engine speed limiter….i could take it out and enjoy it for the first time. It’s that synced under WOT.
And it’s interesting when I think about where I’m at now. If I take a step back it’s eerily cool…I pushed this car to the point I have Ryan Martin and Eric Brooks both looking into the software bc right now nobody thinks it’s the hardware.IMG 0306
DadMobile
Texas
I feel like a company with an automotive engineer already made many passes, worked with SCT and HP tuners and identified multiple hardware issues limiting the platform. The biggest being the cams and the other being the PCM for your year car. Many other tuners also verified that the PCM you are using is limited. I wonder if switching out the PCM would solve your issues? Are all those other educated tuners wrong? It seems not based on the issues you’re dealing with.
Keep pursing your truth, you are an inspiration to thousands, maybe millions of car enthusiasts around the world!
Cincinnati,OH
We all told Andrew about this 6 months ago and he didn’t listen. This ***** just discovered basic operations in forscan the dealer teaches **** techs. But chat GPT has got him thinking he’s a software engineer.
802SHO
Ryan mentioned maybe they end up flashing me to a newer model year OS but that would be a 2012 …it also feels like this limit must be accessible in SCT. Like in my opinion Home Depot is way better than Lowe’s but if one doesn’t have something the other has it.
While waiting I can’t help but wonder about what ends up happening. Eric finds it and exposes it? Or if 2012 has a more appealing OS, maybe Ford changed some stuff 10-11-12?
Stuck in the queue waiting to hear a solution
IMG 0369IMG 0377IMG 0361IMG 0357IMG 0346IMG 0341IMG 0336IMG 0335IMG 0334IMG 0333IMG 0381
