Zpak
Es Aich Oh!
Yeah that would be my question. If it’s not needed, where am I getting the ounces of oil from?
My 13 has a oil separator on the valve cover and I get this out of my UPR CC every 3k miles.
And I'm guessing your catch can is before the oil separator?
I'm not saying they don't catch oil, because they do. I'm saying I don't see owners without them having valve deposit problems like BMW and Mazdas have.
Are these preventing a problem that doesn't exist on this motor?
Adding PFI to a DI engine is a non brainer and I'm surprised they aren't all doing it already. Just tap into the fuel line ahead of the HPFP, add a rail, injectors and some software.
No way is the dual system in response to valve deposits. That's just a side benefit. It gives the calibrator so much flexibility to use PFI at idle, DI at WOT and blends in between. The are trying to combat particle emissions without having to resort to particle filters much like the diesels. (There are upcoming regulations limiting particle mass, PM).
If you can get access to SAE papers, there's lot of great reading:
https://www.sae.org/publications/technical-papers/content/2018-01-1415/
Adding a tradition PFI was a big reasons. Regardless of what you think, the auto manufacturers know and spend way more in R&D then you and I. The engineers didn't forsee in the future with the issues of DI motors and the intake valves. If they did they would have had dual fueling systems since day one. They are more expensive up front with R&D and manufacturing, so....unless a problem surfaced (which it did) there was no reason not to only have DI. The real world changes things....funny how that happens.
Ford absolutely saw the issues ahead of time. They codeveloped their DI engines with Mazda. Mazda engines had major intake valve deposits issues long before the Ecoboost family of engines came out.
I doubt that. There is too much cam stuff in the way. You need to go through the spark plug holes and look around. The bore scopes have the flexible end that can bend up and around to get different angles. There you can see valves in different stages of opening and closing. There are youtube vids with some footage of various cars valves.If you pop the MAP sensor off, is it clear path the intake valves to take a look with a borescope?
I'll answer my own question with a yes. MAP sensor hole is in the direct top dead center of the intake - straight shot to the center cylinders.
This is with a super cheap ($15 Amazon) DBPower endoscope. 43,000 miles without a catch can, 10,000 more with (JLT). This is right and left valves for cylinder #4 (front, center).
I don't see a problem.
Looks Good. Would be interesting to see a cylinder on the back side.
