Catch can worth it?
Zpak
Es Aich Oh!
The region, Indiana
A9374A53 DCC5 4262 BD1B D38161B1ABF0 Case closed! For any doubters or people on the fence about buying a catch can this is about 1,200 miles since last empty. I’m assuming the cooler weather has been a factor to increased volume of nastiness not pumped back into my engine. I usually do it at 3k oil change intervals but I was starting to smell it so I knew it was time.
EcoBoostSHO
Minnesota
View attachment 11349 Case closed! For any doubters or people on the fence about buying a catch can this is about 1,200 miles since last empty. I’m assuming the cooler weather has been a factor to increased volume of nastiness not pumped back into my engine. I usually do it at 3k oil change intervals but I was starting to smell it so I knew it was time.
That's a lot! Which can are you using?
Sent from my Pixel 3 XL using Tapatalk
76FoMoCo
Nampa, ID
so I have the lms can and I don't see seet on a 2013
wtf am I missing besides the smelly hoses ?
b4black
IL
Most of what you are seeing in those pictures is water. No value in catching water (which was vapor until the catch can condensed it out). Catching oil - yes, water - no.
Actually, if anything, water vapor would help remove intake valve deposits.
Your first picture above is about 80% water and 20% oil.
You clearly don't know what you are talking about. Your numbers are mixed. It is 80% oil and 20% other liquid. I know, I pull it out of my UPR catch can every 3K miles.
b4black
IL
You're right, I got them backwards. Oil floats on water. The colors threw me off. My oil is black. Just like JRV1631's above (although in the winter, it's more milky looking with water).
Any thoughts as to why your 'oil' is so light? Could it be fuel dilution? And why you seem to have so much more?
I thoughts as to why your 'oil' is so light? Could it be fuel dilution? And why you seem to have so much more?
The oil that comes out of my catch can is always dark and always smells like fuel.
stripSHO
Idiot Savant
Detroit
Right, oil floats on water, so your 80/20 water/oil for the first pic would be correct if that's oil and water in the bottle. But I'm also curious why Zpak's engine appears to be breathing chocolate milk and beer
Zpak
Es Aich Oh!
The region, Indiana
The original picture had most the oil and milky foam spilled off before the rest made it to the bottle. This was the fist time I saw so much liquid. Like I said, I’m assuming because probably a good 500 or more miles of the 1,200 were driven in under 20° F weather. I’m not sure why, previously vapor or not, you’d want that sucked into the combustion chamber.
b4black
IL
You wouldn't want to suck liquid water into the engine, but it was a vapor before the catch can condensed it out. That tiny amount of water vapor (without a catch can) wouldn't hurt anything.
The "chocolate milk" is the oil layer. It's actually an oil and water 'emulsion'. Just like when someone blows a headgasket and their oil looks milky. The 'beer' is just dirty water.
hosbaldosho
