Magna
- Joined
- Dec 11, 2017
- Messages
- 62
- Reaction score
- 36
Removed the snow tires yesterday and back to Summers. Looks 100 times better lol
Thank youLOVE the AeroForce set up...nicely done!
Sweet, I have the duals also. Looking good !!View attachment 6420 View attachment 6421 View attachment 6422 View attachment 6423 Today I washed my baby put on her summer sneakers and bought her a gift for being so sweet, duel aero force gauges to make sure she is running optimal
Yes it doesI should have asked....does that speaker grill just pop off?
Real easy if you want i can tell you how then buy a spare grill cover to replace when done.. AeroForce gives you pretty detailed instructions on the drilling to run the wires..Those really do look nice. Wish I had the guts to mount something like those too. Good job.
Changed engine oil, PTU fluid and RDU fluid. Rotated the tires. Painted the calipers. I was kind of ticked off after doing the PTU. I was lucky if I got out 1 oz of old fluid. Used two different size hoses on my suction pump but to no avail, so I figured I would fill it and see how much was in there. Well to my surprise it took 14oz of fluid before it started to seep out of the hole which tells me I had only had around 4 oz in there vs the 18 required. I have had a harmonic vibration between 40 and 45 for awhile, after changing the fluid and rotating the tires I thought it would go away. Well it didn't. I have a sickening feeling I'm heading for a PTU failure. Needless to say it will be visiting the dealer since I only have 37k on it. On a side note the little bit of fluid I did get out was actually pretty clean and the magnet looked decent. RDU was a tad low, sucked it out and was able to get 32ish ounces back in.
Ordered new roof moulding strips as the old ones were rooting away.
Sent from my XT1094 using Tapatalk
