89-95 MTX repairs
OG-SHOguy
Same as JBeck
Houston, TX
update...I am pulling out all the stops and still looking. I refuse to give up on this one!
OG-SHOguy
Same as JBeck
Houston, TX
Good luck. Seen this movie before but keep hoping for a different ending
I know what you mean....I have hit so many dead ends in the last couple days but someone out there will make these...i will do my best to find someone who will. Like i said before, if i can get ahold of a new unused set 1-5 or a really low wear set then I can make them myself but it will be really low numbers because i will be hand machining them from scratch.
OG-SHOguy
Same as JBeck
Houston, TX
I read the same thing! "Made in Japan" that means im on the right path so far... today i sent out emails to Mazda japan corporation... maybe, maybe, maybe... we will see
Also noticed that looks like a set of synchros... any chance i could get a hold of those to get a 3D model of them? I promise i will take care of them and make sure you get them back!
pjtoledo
'ol man in the SHO
toledo,ohio,usa
that's the only ring with a W/O on it, the other 4 are generic bags. those 4 are the fiber lined type.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
yes, that is a full set of NOS synchros. I've had them for many years, they were supposedly the last ones at the time. or maybe the guy just said that to justify the price.
I'll wait and see how serious the death threats are before letting them out of my site.
OG-SHOguy
Same as JBeck
Houston, TX
I understand
Is networked CAD design/mockup a reality? The idea being the item would never leave its' physical home.
you could take them to a machine shop with a CMM and have them do a full inspection on them to get the real dimensions. It would likely be around $200 each to get that done, but some of the newer CMMs will generate a solid model or stp file if you want. With that process, pjtoledo would never have to let them out of his possession...
LOUDSHO92
Rancho Cucamonga, CA
I would recommend a place with a blue LED or laser scanning system. They make a point cloud system to make a full CAD model. CMM is individual points so it takes a long time. I have seen thr blue LED system scan an entire engine block in only a few minutes.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
I wonder how it would register the fiber lining, or the surface under the lining?
the syncros appear to be cast, only the inner friction surface was machined before the lining was attached.
OG-SHOguy
Same as JBeck
Houston, TX
that is a raised rectangle in the opening.
Can you post a clear image of all the part numbers on the nags you have? I got an email back from Mazda corp and they are asking for part numbers but idk if the ford numbers will suffice... the W/O number is i think what they need as it would have been a work order number
pjtoledo
'ol man in the SHO
toledo,ohio,usa
the other 2 packages are generic "write-on" baggies with only the hand written part number. there are 2 rings in each bag.
E9DZ-7107-A, the rings in that bag have YF14 in ink on them.
E9DZ-7107-B, those have ZD22 in ink on them.
the Ford packaged ring is E7FZ-7107-A. it is not fiber lined, there are no other markings on the ring.
the "F" in the part number has me a bit concerned, but our transaxles are a beefed up version of the Tempo (????) so maybe that part carried over.
the other numbers on that package:
F747A W/O 033542 090701
hope this helps.
OG-SHOguy
Same as JBeck
Houston, TX
At this point i am trying to get anything we can get. I have someone with Mazda that seams like she wants to help so i am trying to get her to trace back or get in touch with Mazda Japan to at least find a campatability part if not the original components... so far so good but our cars are over 20 years old so just being hopeful at this point. Thanks for the help PJ!
snowwind1990
springtown, tx
MTX-IV[edit]
The MTX-IV is a beefed-up version built by Mazda and introduced in 1989 for the Taurus SHO. It was also used in Tempo/Topaz models equipped with the Vulcan V6. Installing this transaxle into a V6 Tempo requires the use of a Tempo-specific flywheel, clutch, pressure plate and CV axles. This transaxle has also been used in the aftermarket to convert a 3.0L Vulcan-powered Taurus to a manual, something which was not offered from the factory.
Gear ratios (Vulcan Tempo/Topaz[1]):
1 2 3 4 5 R Final drive
3.60 2.12 1.39 1.02 0.76 3.62 3.52
Gear ratios (Taurus SHO[2][3]):
3.21 2.09 1.38 1.02 0.74† 3.42 3.74†
† - The actual 5th gear ratio is 1.02:1 (same as 4th gear), but it runs through a different final drive gear from gears 1-4 and reverse, with a ratio of 2.73:1, thus giving it an effective gear ratio of 0.74:1, if one assumes that it has the same final drive ratio as the rest of the gears.
From Wikipedia
TimboSHO
Intermediate
Wyoming, MI
Subscribed. I used many of my brand new parts to rebuilt the wagon transmission. I have a bunch of spare transmissions, but I'm in need of a few parts for my 89 some day.....
shobroooo
