89-95 SHO Massive Performance Parts Sale
1993MTXSHO
Its a Taurus...
Jersey
Thread title speaks for itself. It's time to let it go. Instead of blasting the thread with 50 picture's I'll just post a few but I do have pictures of EVERYTHING. So just shoot me a PM with your cell number and what you want a picture of and I'll get one sent. Any questions let me know.
Also interested in trades on some stuff I'm looking for for my 93 MTX if anyone has the below and would like to trade or even flat out sell:
Trades:
New Main engine bearings
Long tube Headers
Any NOS Ford parts
Mint Condition (at least plastic wise) 92-93 SHO rear bumper in "PA" paint code. I do not want anything with any scratches or gouges in the plastic, no cracks etc. I prefer paint to at least be fair to good but I'm mainly concerned with the plastic being perfect for when I repaint.
Just added:
$160 - Pair of NOS Ford cam timing chains
$50 - 93-95 atx alternator
SOLD - Front factory strut housings modified for koni inserts with spacer rings
SOLD Almost new drivers side headlight without fish tank.
SOLD Dual Bluetooth 200 watt headunit
http://www.crutchfield.com/S-9LIHdnoMGU5/p_070XD6415/Dual-XDMA6415.html
SOLD Clear corners
SOLD Pair of newer headlights (fish tanks are original)
$100 Hard button EATC
I'm also pulling parts out of my 92 mtx interior since it's getting stripped to be a track car so let me know if there is anything you need, it's gray. Front seats are in decent shape also but do have a couple rips.
SOLD - Pile of gen 3 parts I have no use for since I don't have a gen 3. I would like to just get rid of them all in one shot but I'm willing to sell individual parts too if necessary. I honestly don't even know what all is there but I'll list a few things I remember seeing.
-What look to be brand new Gen 2 front springs on brand new Gen 3 Motorcraft front struts (these should fit the gen 4 Taurus also).
-Huge pile of coil packs I would say at least 10
-What looks to be a complete intake manifold upper and lower, throttle body, engine vanity cover etc. (would be great to do some port work on while still driving your car)
-Air intake with MAF
-Instrument Cluster
-Interior dome light
-Some Mach audio speakers (not a complete set, I think it was just the tweeters and covers)
-Pair of headlights
-Probably some other random stuff but I have no idea what it is, I just need it all gone
Wheels:
SOLD Set of 4 17x8 5zigen FN-01RC (VERY light wheels, probably somewhere around 17lbs each)
SOLD Set of 4 17x7.5 Sport Edition F7
SOLD Set of 4 17x7 SVT Thunderbirds (two have bends in them, but they're not too bad, however 1 of the two wheels has 2 bends and the 1 bend does have a small crack so will have to be repaired. Wheel didn't leak when tire was mounted on the car so should be an easy repair for a wheel repair shop.
$40 (1) 17x7 MSR 190 Wheel
Suspension/Brakes:
SOLD TCE 13x.81 Willwood BSL 6piston Calipers with the original Gen 1 Knuckles and brackets with the stainless braided lines. At least one of the 2 needs a wheel bearing I think. It's very stiff and doesn't spin well but may free up if you move it around a bit. I think I have some NOS Ford wheel bearings I could include for an extra cost if desired.
SOLD TCE Rear Knuckle Braces
SOLD 13" Mach 1 Brakes -- Comes with calipers, and rotors (Rotors have surface rust and need a resurface). My understanding after some research is that they can bolt directly on the knuckle and run a smaller rotor or you can use a bracket and use the included 13" rotors but I do not have the bracket so you will have to have one made or find one online
SOLD 4 Front Koni Struts, 1 pair needs to be sent to Koni to be rebuilt, the other pair is good
SOLD Front and Rear Carbon Fiber Strut Tower Braces with brackets set
SOLD SHOSHOP rear strut brace for JBL sub (missing mounting hardware and brackets, this is just the bar)
SOLD Ingalls Adjustable Rear Control Arms
SOLD Adjustable stock rear control arms (only 2 of the 4 are adjustable but you can probably buy another kit to make the other 2 adjustable if your car requires it)
SOLD New metal 89-95 Sway bar endlinks (Some surface rust on one)
SOLD Eibach Ground Control Springs Brand New in the box (Part# GC230.64.49 and 200.64.67)
SOLD Eibach springs with 1 coil out of the fronts and 1/2 cut from the rear. I only have the 1 rear spring because I accidentally cut the wrong end of the spring (bonehead move) so these are now useless to me but would be great for someone looking for a spare set in case one of theirs breaks or if they just wanted a pair of fronts to run with a different pair of rears. $75
Other:
SOLD SHO Shop Fenderwell CAI (no filter, functions fine but it's a little beat up)
SOLD Complete SHOSHOP CAI with Carbon Fiber Can, MAF/intake and fender Airhorn
SOLD MTX Transmission (Sat outside, good for parts or at the very least has to be opened and cleaned up)
$SOLD Black A Pillar Pod with Auto Meter Oil pressure and Oil Temp gauges (no sending units and oil temp needle is a bit faded)
$35 89-95 Valve Covers
$10 89-95 Used plug wires OEM in great shape
SOLD Gen 3 Grab bag box (headlights, intake manifold, Intake airbox and maf, instrument cluster, alternator, tons of coil packs, some Mach Audio speakers, overhead console, etc. take it all I'm not a gen 3 guy and don't even know what all is in this box apart from what I remember seeing)
SOLD 92-95 Projector Headlights professionally done with brand new spare lens' (have some dirt in the housing and have to be cleaned out)
SOLD 92-95 Instrument cluster with white faced gauges and carbon fiber drop in gauge surround
$20 ATX Engine Mount
$40 93-95 ATX Intake manifold
$25 92-95 Tail lights
SOLD 3 piece torque limiter kit, little surface rust but functions fine
SOLD 2 piece SHOSHOP UDP Kit (also have an original under 2k mile crank pulley that SHOSHOP forgot to put the roll pins in so it spun a bit. It's still lined up but will have to be spun back and roll pins installed. I'll include this for a small bit more or sell seperate)
$35 New half shaft, I think this is for a gen 2, has minor surface rust on it but can send a picture so you know what it is to be sure it fits your car
SOLD 89-95 Coolant overflow tank
SOLD SHOSHOP CAI horn (pretty beat up and looks like it has a bullet hole through it too, but still functions as it should)
SOLD 89-95 New Felpro Valve cover gaskets
SOLD Pair of brand new Summit Turbo Mufflers
SOLD 92-95 Pair of Fishtank lights
0430161921 zpssfh2tcqo
1993MTXSHO
Its a Taurus...
Jersey
Also as a note guys I will be at the Carlisle All Ford Nationals with my truck in PA next month. So I can bring anything up there to meet up and save shipping charges if anyone is interested.
shoray
Hinesville,Ga
Are the front Konis already in stock housing or have they not yet been installed? Very interested.
shoray
Hinesville,Ga
Being in the stock housing is a good thing. I've been searching for them forever :). PayPal?
broke1
Alabama
Package deal on $100 cold air kit and the thunderbird wheels shipped to 35226 for $300?
If so,send me a paypal invoice or addy for MO
1993MTXSHO
Its a Taurus...
Jersey
Sorry. Shipping would easily cost me $150 so I can't let all that go only making $150 plus the work of packing it all up. I can do it for 400 shipped so I make 200 to 250 on it if you can do that.
broke1
Alabama
I've shipped SEVERAL sets of wheels over the years(10 sets at least)
Shipping is HALF that amount and I'll bet double or nothing that's the cost with 2 wheels per box is no more than $80.
Did you see the perfect set that sold on eBay recently for $300 shipped? PERFECT wheels......
1993MTXSHO
Its a Taurus...
Jersey
Yes I did see it. In fact my buddy bought it. Well like I said I want 250 out of it. So 250 plus whatever shipping ends up costing me. I'll put 2 Wheels in each box and take the intake apart and put it under the wheels so I can only ship 2 boxes instead of 3. All I know is I just shipped a 30 lb box to Washington and it was 71 bucks to ship. These wheels will be 50 per box and with 2 boxes it will be 100 minimum I would think. But like I said I want 250 plus shipping. So send me 400 and whatever I don't need I'll refund it. If you think I'm trying to screw you I'm not that type of guy. I've just gotten burned on shipped a lot before. I'll even send you the receipt from the shipment so you know exactly how much it costs. Heck I hope you're right, I just don't ever ship wheels because it's always expensive.
bsb1961
Oregon
Interested in the complete sho shop CAI for $300 how much to ship to 97759 pm me please thanks
1993MTXSHO
Its a Taurus...
Jersey
USPS quote is 55 to ship. Probably because you're pretty far away, I'm in nj.
broke1
Alabama
your shipping quotes are 2x as high. Are u going to a you ship it store or somthing?
There's no way that $300 cold air kit is more than $15 shipped via USPS......
1993MTXSHO
Its a Taurus...
Jersey
I've been burned shipping stuff. You go across the country and its expensive. Go on USPS and calculate it. Like I told you with your stuff I'll refund the difference if I way overquoted it. So I don't see why it's such a big deal. I'm calculating the cost online and you can do the same. There's no secret here.
broke1
Alabama
I'm not trying to bust your balls buddy they are just that much higher that it makes you say "WTF?"lol
Going to a you ship store,they charge 2-3x as much so I'm almost positive that's what u are doing....
broke1
Alabama
I've shipped thousands of items,I don't need to get a shipping quote......
When you mail thousands of packages,you will have a good idea what it'll cost str8 off......
broke1
Alabama
Also,USPS and other shippers don't charge on distance,they charge by weight and the size of the package.
Only difference in price is between a residential and business addy.
1993MTXSHO
Its a Taurus...
Jersey
Yeah I've shipped quite a bit myself. And probably 10 packages in the past week. I know how expensive it is to go from the east coast to the west coast. Especially with a heavy box.
Brumfield780
