Tons of parts mtx and atx 89-95
shomike220
Chambersburg PA
I just Recently Went through my stoage garage and this is whats left. All Parts make an offer including shipping from 17201 to your address. Hopefully somone can use some of this stuff. I have pics of everything listed so if you are intersted in somthing and want a pic let me know.
Complete Working ATX Transmission EST 60K miles.
MISC PARTS
VAPS Module From A 95
Keyless Entry Pad
Crank Cancer Repair Parts(Timing Gears,Bolts,Keys)
89 Clock
MAF's
MAF Tubes
Air Box Lid
ATX Alternator Brackets
ATX Pulleys Less Belt Tensioner
Grey Armrest From An 89
Shifter Bezel From An 89
Gen 2 tail lights (2 sets)
Coil Cover
Metal Bracket on MTX Trans
MTX Crank Pullies
ATX Crank Pullies
ATX Exhaust Manifolds
MTX Exhaust Manifolds
ATX Exhaust Manifold Heat Shields
MTX Exhaust Manifold Heat Shields
ATX Halfshafts
MTX Axle Bearing Shaft
Gen 1 Trunk Storage Bins
95 Cluster
89 Cluster
ATX Black Cover Behind Motot
Gen 2 MTX Coolant Bottle
EGR Tube Assembly
Strut Covers
Valve Covers
Intakes
MTX case halves
MTX parts
Valve Shims
ENGINES
I have 3 complete 3.0s all running when pulled, if you need any parts off them let me know or interested in one complete.
BODY PARTS
Red Panels Above Rear Bumper Gen 2
White Panels Above Rear Bumper Gen 2
Rear Quarter Glass Gen 2
Complete Gen2 Front Bumper Less Fog Lights
Gen 2 rear Bumper Cover Only
Complete Front Bumper From an 89 (Grey)
89 Header Headlight Panel With Grey Trim under Headlights
89 Door and Rocker Moulding Less Drivers Front (Grey)
zak
east of Hartford
What color is the 92 front bumper cover? Any chance you have the left fender? Have a trip to Reading PA pretty soon.
tery
Silvia survived the purge- summer car
minnesnowta
Hi, Two things, What do you think it'll cost to ship the alternator to MN?? and fit 93 of course?? and can you rate the alternator in terms of *** I should expect it to perform??? Probably hard to answer really, but your best guess is all I'm thinking... and the '92 fog lights will fit a 93...correct?? I'm a newbie still?? When you have a minute, tks
Terry
shomike220
Chambersburg PA
Terry
PM sent
operdot
USA
ATX Tensioner
I got the tensioner today and it is in great shape, thank you!!!!!!
Recommended seller.
:thankyou:
1badsho
Port Charlotte Fl
does the 89 have a decent working cruise servo where the wire to the servo is hard wired . ... not a quick disconnect as the later cars had. Need one for my 90 SHO
ahelm
CT
Do you have a timing belt tensioner spring? Also, what shape are the motor mounts in? Thanks.
