TimboSHO
Intermediate
Don't pull the intermediate shaft if you don't have to, and if the seal isn't leaking.
Okay. I'll just leave it in and just replace the CV axles themselvesDon't pull the intermediate shaft if you don't have to, and if the seal isn't leaking.
Crawling around is one thing. Trying to wrestle off rusted old junkyard axle parts is not something I want to do.you can look at a regular Taurus of similar vintage. I assume there may be a mercury sable equivalent. If in doubt and looking for a used piece, Dan Barbush Sv&HoDan is near Pittsburgh and the PA SHO shop is closer north of Harrisburg. Not sure if Brian (or does he go with the Bryan spelling?) has used stuff like that laying around. Should be plenty of car graveyards in your area if you feel like crawling around
Okay so there are two listings... Which one is it? The thicker one? or the thinner?NAPA CV joint boot kit has the clips included. I'm sure there are other sources.
Well I have seen a few. One is using a prybar and popping it out. Another is a slide hammer with a special end that's specifically meant for removing a drive axle from the transmission.If you have an existing C-Clip, even if it is broken, you can take the measurements with calipers, and you will be able to buy a new one. They follow a set of rules in shafting design (just like O-Ring glands) and they will be available from fastener/ bearing supply companies.
I would use the old ones, but get some advice on removing them, as there is probably a preferred method.
Yeah, that's what I was probably going to do. Just some tapping on it after the shaft is out of the spindle. Judging but whats holding it on (mostly nothing but the locking nut on the end, a locking clip and the spindle itself), it shouldn't hopefully take very much to pop it out. I'll know in the next few days. The new control arms come in tomorrow, but I got to work the next few days so I won't have anytime for the car until about mid week. Thanks for all the help and advise. I would't have even attempted this without. And I really want to because I know my local shop will charge me like300-500 just to install them.I was able to go under the car and hit the inside solid end (out towards the wheel) with a hammer and chisel, it didn't take much to pop it loose
