Plugged a tire.... again. Third time in 2 weeks. It's not even like it's the same issue. nails the first time, glass the second, and a screw the third.
I am told that you should get the mushroom type repair kit. Slime sells those and apparently work well.Reminds me a need to get a plug kit, never really know when traveling
Sent from my SM-G955U using Tapatalk
Washed and waxed the SHO yesterday, same treatment for the wife's Jetta today. Also installed a the 3 Bar MAP sensor and updated to stage 4 plus 93 3Bar tune. Will eventually get the thermostat as well, so I can rune the 4+X tune![]()
A must with PP.Reminds me a need to get a plug kit, never really know when traveling
It is indeed plastidipped. Been a few months now. When I wash the car, I coat it with tire shine, gives it that glossy finishVery nice! A little off topic but is your grille plastidipped or painted? Looks really good!
Was it replaced very recently? Was it gapped at .050 or is that what it measured when you removed it? As plugs get older they deteriorate and the gap increase. If you measured it at .050 and it had been there for awhile it could have been gapped much smaller when installed.Too bad they gapped it at .050. Gap on the 534's ranged from .037-.043.
Which brake kit?
Interested in this too.Let us know how your Akebono's work out, how the initial bite is in particular ...
Finally got around to ordering my unleashed tune and installing it, took less than hour from ordering to having it in my email, great service.
