Sholab1
Put tune back on, thinking about going to Norwalk Ohio for the Dms shootout with son, maybe some track time Fri night
Sent from my SM-G955U using Tapatalk
Looks amazing! what rotors and pads did you go with?
Yes only fake new car smell i like the bomb works greatI work for 3M, so I get discounts on Meguiar's products. Car passed 78k miles and while it smells pretty nice inside, it could always be better. Vacuumed it out and it's currently being bombed as I make this post since it needs to run for 15 min.
Edit: May be too early to tell, but I wouldn't say it's a new car smell. Has a hint of vanilla, otherwise it's an nice smell I think... I'll give it a few days to air out and see what it's like then. If anything, it's better than it was so that's all that matters!
Thanks alot! Akebono ProACT pads up front and Wearever Ceramics in the rear. Rotors are high carbon HD units from a wholesaler in Canada. Fronts are drilled with chamfered holes and the rears and drilled and slotted to the edge of the rotor. Unsure on brand. But after I cleaned and lubed the slides (2 pins were showing rust formation from lack of grease), replaced the slide boots, and installed everything, the braking difference is night and day. I had a nasty vibration and shudder during initial break in, but it was just the rust preventative coating wearing through the pads and rotors. I've put about 150 miles on the new setup and braking is smooth and exact with no more vibration although i'm still wearing through the coating. I know I could remove everything and scuff the pads, but the pad to rotor surface should be nice and married after a few more hundred miles. Bite and pedal feel are unbelievable. I ended up having OEM rotors on the car front and rear. My car just hit 70k miles. The front rotors came off shedding pieces of rotor from the inner veins nearest the hub due to rust formation. Seems like the car had been pad slapped all it's life and the slide pins were never checked for lubricity. Needless to say, the car stops on a dime and looks a lot better through the wheels now that everything is clean and painted. Going to coat the front calipers with M-Sealer just like I did the rears after a few more heat cycles. I like to paint them with high temp paint and let them cure over night then heat cycle the brakes during break-in to further cure the finish on the calipers. Then seal them with M-Sealer. Process is fairly tried and true and helps when it comes to detailing the car. The brake dust simply washes off with light agitation leaving an excellent semi-gloss finish.
So I received my tuner from Torrie yesterday and his tune. Still waiting on a 3 bar map from rock auto tho so I haven't been able to try out his tune but I did try out the 93 canned tune for my 2 bar map and it made a huge difference. I'm telling ya rock auto can't get here soon enough, I'm dying to see how my car reacts to Torrie's tune. I do have a question someone can maybe easily answer? ( I searched the forums with no luck) how do you change which gauges (pids) that you want to look at? I briefly looked at live wire before I left work but seemed like alot of work just to view a different guage IMO.
Before I had the tuner I would just use my scanner from work to watch all my live data, just select and scroll and really easy peasy. Lol funny the scanner was way more money and doesn't make your car go like a scared cat so I'll stick with the tuner. I'll let ya know how it goes once my map comes in and I get Torrie's tune set up
That's what I use inn mine. I really like it, and it lasts a very long timeI work for 3M, so I get discounts on Meguiar's products. Car passed 78k miles and while it smells pretty nice inside, it could always be better. Vacuumed it out and it's currently being bombed as I make this post since it needs to run for 15 min.
Sent from my SAMSUNG-SM-G930A using Tapatalk
It's a Lincoln, so I guess smelling like an old man is appropriate anyhow.
