My take on fixing the tail light chrome trim!
TheDecalGuy
Johnstown Pa
I make decals and such (hence the name) and I had some chrome vinyl in my stock. Figured I'd give touching up that awful peeled trim a go.
Here is the before:
KvssaWE
Here is the after:
A0Q0dHg
I probably should have continued doing the top corners so it would all match. But my back's sore, and I feel accomplished enough.
jpena157
Here is the before:
KvssaWE
Here is the after:
A0Q0dHg
I'm gonna fix mine this summer...will remove my lights, sand down all the chrome as much as I can, primer and paint black ...possibly may try plasti dip 1st
Sent from my SM-G935T using Tapatalk
jblauvelt02
Plastidip is the way to go man. Cheap easy and reliable. I've used it for many things
jblauvelt02
Ok, thanks... I will give that a go first for sure then
Post pics man. I plan on doing that large chrome piece on the trunk once it stops raining by me.
ridered74
I used plasti dip on mine about two years ago. Didn't remove the lights from the car and it has held up fine, looks the same as when I put it on two years ago. If you've never used it, watch a couple videos so you can get an idea of how far to put the tape from the chrome. Most important thing is to make sure you cover all the paint between the part you are painting and the tape so that it all comes off easily when you peel the tape.
Pic below was from the same summer that I did it. I'll take a picture tomorrow so you can see what it looks like 2 years and 30 or so car washes later. It might be slightly faded compared to when I put it on, but otherwise looks flawless.
Dvg38y
jpena157
Dvg38y
Bro, that looks fantastic...can't wait to do it !! It's such an eye sore to me !!
ridered74
Ya, it definitely is an improvement over the peeling chrome. I think the key for the plasti dip is lots of coats. I probably did 10 or 11 on the tail lights. Spray it on, give it 10-15 minutes, then spray another coat. I was trying to use the entire can on just the tail lights, but ended up giving up after a couple hours of spraying it every 10 minutes.
Here's a picture of them from a couple minutes ago, not much different than the day I did them two years ago.
jpena157
Yep, still looks great
jblauvelt02
IMG 0838
IMG 0840
Works very well on the trunk chrome if anyone was wondering. It's been really rainy so sorry for the pic, but you get the idea
aurmend
Nice, I used vinyl wrap.
5b75edbde08cd80592c0944dde02d53b
Sent from my SM-G930V using Tapatalk
SilverSH0
Did my tail light chrome yesterday and today B96afbee174301cb55251e2c26bff320908f235568e20aad44318b28a5b983fa2123f25cde40ff7d01d23e4476ed58a4561bb6a8aa7102903afdd600e6f6269885a67bfb225b50485193fdc1090e4a138deacf9255098e944d495ffbc1282aa48cfb8eea6478f6bbafc6d26bd5d3bbdb
I looked for over a year for a SHO that color and never found one with the options and mileage I wanted. Probably one of my favorite colors....looks great.
jpena157
Thank you ...it was less than 40k miles with absolutely every option other than pp package
