914-SHO Project Thread
3d914
OK, got the lower-left corner repaired and the panel pre-cut.
Post 1191 1478474634
Then got it trimmed & test-fitted so I could mark it for cutting. Marks came out good on the back, but I'm going to refit it tomorrow and mark it again to see if they come out the same.
Post 1191 1478474645
3d914
I spent over six hours this weekend just working on the fit for this panel. That's on top of helping my daughter with her car, working with my wife on the pond, and getting a little chill time relaxing with my wife planning our bedroom renovation.
I don't have a lot of experience with this other than what I've gained working on this car for the last (I'm embarrassed to say) eight years. I don't have all the time-saving tools a regular body-shop would have either. The typical challenge fitting panels on the 914 is all the curves and radii. In this case I had the door handle pocket to act as a guide at the upper left of the panel, and the alignment along the bottom of the door for another. There were two more alignment references needed; a dimension from the front quarter-panel seam (under the door) to the lower-rear edge of the fender; the other a dimension from the back side of the lower channel to one of the fixed suspension mounting points.
Because my patch panel overlapped my cutout edges (see pic above), and with these four references, I was able to start at the front curved edge and mark it on the back of the patch - using the edge of the cutout as a guide. All marking occurred after checking each of the four positional references. I then would cut half the material off up to the mark. So if there was 1/4 inch of material, I took off an 1/8 inch. That allowed me to creep up on the mark. I didn't have another panel on hand - so I was careful not to botch this one.
Post 1191 1479084554
Next I worked on the door handle pocket. The patch was different than mine, so I had to spend some time reshaping and getting the two to line up properly. I continued to do this all the way up until the final fit. As I completed fitting each edge, I would re-verify the four reference positions.
Post 1191 1479084567
I then moved to the top edge. This was a little trick because I didn't have a good way to secure the bottom channel and every time I wanted to adjust the panel at the top, the bottom would move also. Finally I started using the support bracket that connects under the back channel to the inner body. Mine was pretty beat up, but I was able to reshape it and make it usable.
Post 1191 1479084578
The next section to fit was the back edge along the hip of the fender. I left this as an overlap because it gave me one less loose corner to have to deal with when fitting the panel. Now with the others fit and the four positions verified, I was able to mark this on the back and cut.
Post 1191 1479084590
Then I was able to use a couple welding clips to fasten things and verify the fit and all dimensions. This is also when I did additional sanding of the patch edges to provide a small gap for welding. I generally use a black marker to mark the front of the panel where the edge needs to be sanded/filed.
The final cutting needing to be done was behind the FG flare. I've already cleaned it so it will be ready for panel bonding cement - which I'll do after all the welding is finished.
Here's the final fit with the level as a straight edge - carrying the line from the door backward along the panel.
Post 1191 1479085666
3d914
In addition to getting the left panel fit, I was able to get it tack-welded in and had time to tack the right patch in also.
Left side
Post 1191 1479086426
Right side
Post 1191 1479086439
This is what makes this project all the more amazing. Your patience and perseverance provide hope for others who wish to do the same.
3d914
Got a little more done on the right panel this weekend. Weekend went kind of crappy, so didn't get all I wanted done. Decided to take Monday off to make up for it. Glad I did.
Welding on the panel went well. Just combined multiple spot welds at alternating positions and used compressed air to keep things from getting too hot. I'll save the grinding with a 80 grit flap disk for during the weekday evenings.
Post 1191 1479770924
Post 1191 1479770934
Picked up my cut mounting brackets for the trunk hinges. Started working on the flanges already and will finish the others once I get the circular ****** tool in this week.
Post 1191 1479770775
Also had time to start cutting the air box out of the 1/8 inch ABS sheets I found online. I was concerned about the amount of heat this may take in the back of the trunk above where the muffler sits, but I'll be retaining the stock heat shield and will also have this mounted a couple inches up off the trunk floor. We'll see how it goes. I may need to rebuild later from slightly heavier material.
Post 1191 1479771121
3d914
Had to move part of the work indoors because the garage is getting too cold to work with this plastic. The glue I'm using also requires warmer temps. Next time though I think I'll try a plastic welder over the glue, or find glue in a better dispenser so it can be applied cleaner.
Now I just need to add the rubber seal that goes along the top edge & mates with the underside of the trunk lid.
Post 1191 1480016063
Post 1191 1480016107
Post 1191 1480016116
3d914
Didn't work on the 914 over Thanksgiving weekend. Promised my wife I'd get the flagstone laid out for the patio and work on setting her step stones. I did get the flagstone laid out and numbered - and fortunately I won't have to do much chipping/cutting for fit. Now I'll have to pull it up to put the aggregate down to set the stones in.
Had just enough daylight left today to get six of her 18 step stones set in mortor.
Post 1191 1480307224
SHOdded, would that be a new form of "forced" induction?
If you see it in the movies, it must be true!
That'll keep you busy!
3d914
figured I'd post update pics for the trunk hinge mounting brackets. Picked up a 1.5" ****** die and used it to get the angled ****** I was after.
Also have some work to do on my daughters car that threw a rod. That may wait till next weekend when she has some time off. Ohh, the fun never ends!
Post 1191 1480716866
Nice! Didn't know tho that the MR2 had gotten so ... sculpted :) Kinda lost track in the mid-80s.
3d914
SHOdded, you're not missing much. The first couple gens of this were hideous. The third gen (00-05?) were half-way decent - especially since they went to a convertible.
3d914
Well it looks like I won't be getting the 914 painted as soon as I had hoped. With the motor to swap on my daughters MR2 and a bearing replacement to do on my son's 996, I spent my painting money on a single-post lift. I've done enough repair work under cars on my back - figured it was time to upgrade.
This is the Eagle single-post lift rated at 6000lbs. So I'll likely be busy getting this together over the weekend.
Post 1191 1481939115
My wife and I already spent the most of the day unloading the beast. Here's all the packing material: a metal support frame, encased in a wooden crate. And my make-shift ramp I built from some of the crate material - so we could roll pieces off the trailer.
Post 1191 1481939130
Wow! Treat yourself first, then it will be more enjoyable when you treat your goodies :)
3d914
As of around 2:30 this afternoon, I now have a working lift in my garage. What a relief. First car to go on will be the daughters MR2 - so we can get the motor pulled next weekend.
The fun continues . . .
Post 1191 1482106572
