Finally did it!
influence2006
Received my 3 bar MAP sensor. A pain install because the screw wouldn't come out.
Got the SCT tuner, which ended up not working well but after some TS i finally got it.
Emailed with Torrie and got my custom maps.
BROKE THE TIRES LOOSE TESTING IT OUT!!!!
OmaHahn
Omaha
Did you use the correct Torx screwdriver?
influence2006
No I ended up sawing in a line, this way i could just use a flat head. I have a garage full of tools but none worked....
