The Quick Inexpensive Guide To King Kong In Your Trunk...
Unknown_Driver
V6TwinTurboAWD
Ontario Suburbs
Start By Removing the Trunk interior Panels
IMG 3256
to start, lift the (trunk opening scuff plate) black plastic where the trunk latch is up towards the sky it will pop out fairly easily, next unscrew every sticking out plastic tab on the sides near the tail lights and the trunk net hooks now take a grommet removal tool and pry on every flat body panel grommet (some are very difficult to remove fully) you will also need to fold down the rear seats to access 2 grommets,
next step door sill plate... you will need to lift up the door sill plate firmly they are very difficult
now grab your power wire and find out which grommet in the firewall you want to pass it through, this is entirely your decision but everyone has chosen a different route (the one i used is not recommended and won't be mentioned in this post :rofl: ) the best route is located just below the drivers side wiper :dribble:
if you own an older model amplifier that requires a remote turn on 12 volt positive signal, under the steering wheel well above the brake pedal (way up in there) you will find a fuse box thats not easily accessible by anyone taller than 4'6 and a body contortionist ex upside down pole dancer, in your manual you will find a mini fuse labeled "delayed accessory fuse" this is where you will be adding a tap-a-fuse, add-a-circuit connector thing. run your remote wire to this :naughty:, for added safety i also added another low amperage inline fuse closer to the amp (do not use any fuses with more than 10 amps with any tap-a-fuse type of connector)
now to grab that audio signal...
don't touch anything here its hopeless :rofl:
IMG 3253
you will need to pull down on the liner covering the subs in the trunk, just pull down firmly, you will find velcro and a few useless body clips keeping it in place, take any line converter the best choice would be an Audiocontrol LC2i, i went with a Scosche 2 channe LOC80 rebranded as E2 at canadian tire which handles 80 watts per channel, wrapspeaker wire on the terminals of the factory subwoofers (this allows you to keep factory bass going, no neeed to splice any factory wire) now twist the other end of the speaker wire to the line converter wire and wrap with electrical tape or shrinkwrap (soldering would be awesome) now grab some 2 way adhevsive sticky tape and stick your line conveter somewhere onto the side (probably close to the tail light access flap screws so you can make adjustments down the road)
now to find a grounding location for that negative wire this is entirely up to you, some people sand a random metal spot and bolt it or if you were me, attach it to the grounding plate where the factory amp was :naughty:
now perform a quick test with everything wired properly don't forget you must have a fuse close to the battery on the positive side of the main power wire, please use the proper wire gauge for power do not use anything smaller than 8 gauge for whatever reason as it may result in a fire.
everything run fine? tuck the wire in the door sills reconnect the panels and tune to your ears content :dribble:
congrats you now have king kong in your trunk
IMG 3257
Tools you will need:
Electricians Pliers
Wire Cutters
Sharp Scissors
Digital Multimeter
Panel Removal Tool
10mm wrench
More Pictures ASAP i was too busy driving around :rofl:
couldn't believe i spent most of my time checking the voltage of every connector/fuse/light socket just to find a 12 volt remote signal :rofl:
thank god for having an event tent it was 32c today :sun:
IMG 3254
EDIT: UPDATE MORE PICS
this is the fuse panel below the steering column where the add-a-circuit or tap a fuse is located
SAM 1732
to give you a better idea the red wire with the blue connector is the add-a-circuit
SAM 1733
you may want to add another ground point for the battery to chassis connection
SAM 1736
although the rear grounding plate works well just for added safety i added another ground point using an M8 bolt with washer and nut you will need to sand down some paint for a proper ground.
you can also see the location of the line converter
SAM 1739
the line converter was added by twisting on wire to the factory speaker terminals (no splicing to any factory wiring was necessary)
SAM 1740
LotusDriver
Rocky Hill, CT
You could have saved yourself a tremendous amount of hassle by purchasing a line converter that senses audio and provides a remote turn on signal. Just Sayin'.
steve142857
11's in '12 ; )
Quebec
Hi Unknown Driver,
Not sure I will start to do that mod, but I thanked your post for the time you invested in the how-to... very well done. Please post final pictures when you finish driving around... I want to see if it leaves the trunk with decent space.
Thanks!
Unknown_Driver
V6TwinTurboAWD
Ontario Suburbs
yeah i know, you wouldn't believe the trouble i was having trying to find one locally, if you've worked in car audio you'll understand that cost for any item is approx. 40% of the listed price, apparently every car audio retailer/installer in my city either couldn't get what i needed and listed garbage that would take way too long to deliver or charged an insane markup and our current mail strike isn't helping
a good example is one place wanted to charge me $300 for an line converter listed in the US for $80 :rofl: i could buy a new somewhat decent amplifier and have remote turn on built in instead. another problem with lower end remote turn on line converters is sound quality.
does anyone know if crutchfield.com will ship to canada? crutchfield.ca sucks and pretty much only lists what bestbuy has in store :rofl:
dbulldog
IL
Well done!!
I removed my (2) 6.5" Bazooka Tubes and went with this instead. Now a little more room and A LOT more bass!! Just tie high level inputs to Left and Right rear door speakers. LR = White/Green Stripe (+), Brown/Yellow Stripe (-); RR = Brown/White Stripe (+), Brown/Blue Stripe (-). Anyone needing schematics, just let me know.
(2) 10" Polk Audio with a Kenwood 500x2 Watt amp wired at 2 Ohms. All speakers are still utilized with Sony system and navigation. 1 Farad capacitor to ease extra load on electrical system.
IMG 20110619 00033
IMG 20110619 00035
hamrtyme
ONT
IMG 20110619 00033
IMG 20110619 00035[/QUOTE]
i likey much better than the zookas nice clean setup
Unknown_Driver
V6TwinTurboAWD
Ontario Suburbs
UPDATED! ADDED MORE PICTURES
i may add pics of the gf later lol
on a side note when cleaning up wires, always disconnect the positive closest to the battery... i made the huge $500 mistake by blowing my amplifier... i was reconnecting the positive wire to the amp when the screw popped up and landed on both the positive and negative cables shorting out creating smoke and sparks LOL
so now i have a brand new alpine amp :(
SHOrod
Torrie Tuned
Cedar Rapids, IA
I hope you kept the amplifier. I've repaired a few amps after this happened. All that I've run across use an inexpensive diode reverse biased between the power and ground traces inside the amplifier. In the event the amp is hooked up incorrectly the diode conducts and should blow the fuse. Often though the diode melts and also shorts so even if you replace the fuse it will blow again. Replace the $0.50 diode and all will probably be well again.
-Rod
Unknown_Driver
V6TwinTurboAWD
Ontario Suburbs
-Rod
i did take it apart and couldn't find what blew :(
i was trying to find a place locally that could fix it not much luck so far
SHOrod
Torrie Tuned
Cedar Rapids, IA
I'd be willing to take a look at it for you if you want to ship it to me. I don't do repairs for a profit, just for hobby. If you're interested, send me a private message and we can work the details.
-Rod
