my 92 SHO is miss firing and has huge loss of power when check engine light is off. but when check engine light is on all power to the engine is restored.
ive had spark test (good) fuel test (good) and compression test (good). replaced spark plug wires, coil, and spark plugs. and the computer is telling me that there is an open ground and the fuel pump
relay has a bad ground. and ive fixed all possible open grounds, and replaced the fuel pump relay. and i still have the power loss problem when the check engine light is off.
CAN SOMEONE PLEASE HELP ME WITH THIS?
SEND ME A MESSAGE OF WHAT YOU THINK OF WHAT IT MIGHT BE AND I'LL TRY IT. THANK YOU!
