Where's the IRCM?
sho_nuff
Columbia SC
I have a new to me 91 MTX. The PO has the cooling fan wired to B+, so I want to set things right. The temp gauge is also inop and I suspect the problems are related. My question is where do I locate the IRCM to check the circuits? Thanks for any guidance.
Richard
AREA 91
Area 91
Richard
It is located under the radiator cover, toward's the driver's side.
sperold
Last to Know
On the thermostat housing there are 2 different temperature sensors.
The one with the single wire runs the temperature gauge.
The other one, with 2 wires, feeds info to you computer.
TYSHO
Earth
Your temp guage sensor is bad or disconnected. It's located right under the coil pack, on the engine. It has a threaded ****** sticking out, where the L-shape rubber boot connector slides onto.
